Upgrade Process
To upgrade a software image for an HA node:
Confirm that
Oracle® Enterprise Session Border Controller1 and
Oracle® Enterprise Session Border Controller2 start up and are synchronized.
You must also make sure that all of the running and current configurations on Oracle® Enterprise Session Border Controller1 and Oracle® Enterprise Session Border Controller2 have the same number. In the following examples, all of the configuration versions are 5.
On Oracle® Enterprise Session Border Controller1 and Oracle® Enterprise Session Border Controller2, use the ACLI show health command to make sure that all processes are synchronized.
On Oracle® Enterprise Session Border Controller1, show the current configuration version by using the ACLI display-current-cfg-version command. Then use the same command on Oracle® Enterprise Session Border Controller2 and be sure that its current configuration version is the same as the one on Oracle® Enterprise Session Border Controller1.
ORACLE1# display-current-cfg-version Current configuration version is 5 ORACLE1# ORACLE2# display-current-cfg-version Current configuration version is 5 ORACLE2#
On Oracle® Enterprise Session Border Controller1, show the running configuration version by using the ACLI display-running-cfg-version command. Then use the same command on Oracle® Enterprise Session Border Controller2 and be sure that its running configuration version is the same as the one on Oracle® Enterprise Session Border Controller1.
ORACLE1# display-running-cfg-version Running configuration version is 5 ORACLE1# ORACLE2# display-running-cfg-version Running configuration version is 5 ORACLE2#
On
Oracle® Enterprise Session Border Controller1, before loading the software image to the flash, check the remaining space in the
/bootdirectory using the ACLI check-space-remaining code command.AORACLE1# check-space-remaining boot boot: 24759488/25760512 bytes (99%) remaining ORACLE1#
If you see less than 50% of the memory remaining, delete older stored firmware images to make space.
At a minimum, we recommend that you leave the
diags.gzfile and the currently running release on the flash memory (in the event that a rollback is required). - Upload the Oracle® Enterprise Session Border Controller software image file and stage three bootloader to the /boot directory using an SFTP client. See: Upgrade the Stage 3 Bootloader.
Change the boot configuration parameters on
Oracle® Enterprise Session Border Controller1 to use the appropriate new release software image.
From the point that you upgrade the image file, do not make any configuration changes. Likewise, do not use the save-config or activate-config commands. Once you execute the save-config command, the configuration can not be guaranteed to be backward compatible should you have to back out of the upgrade.Access the boot parameters on Oracle® Enterprise Session Border Controller1:
In the ACLI configure terminal menu, type bootparam and press <Enter> to being displaying the list of boot parameters.
Scroll through the boot parameters by pressing <Enter>. Stop when you reach the file name boot parameter.
The following example uses the filenames
/code/images/nnSCX640.gzand/boot/nnSCZ712.64.bz.ORACLE1# configure terminal ACMEPACKETSBC1(configure)# bootparam '.' = clear field; '-' = go to previous field; ^D = quit boot device : eth0 processor number : 0 host name : boothost file name : /code/images/nnSCX640.gz /boot/nnSCZ712.64.bz
As shown above, type the new Release file name next to the previous one, including the path. Press <Enter> to continue scrolling through the boot parameters.
Reboot Oracle® Enterprise Session Border Controller1.
After
Oracle® Enterprise Session Border Controller1 has completed the boot process, use the
verify-config command to confirm that the configuration has been upgraded properly.
ORACLE1# verify-config
Confirm the
Oracle® Enterprise Session Border Controller1 is running the new boot image using the
show version command.
ORACLE1# show version Acme Packet 4500 SCZ7.1.2 GA (Build 165) Build Date=07/17/13 ORACLE1#
- Use the ACLI show health command to confirm that Oracle® Enterprise Session Border Controller1 is the standby system.
As you did for
Oracle® Enterprise Session Border Controller1, configure the boot parameters on
Oracle® Enterprise Session Border Controller2 so to use the new Acme Packet Release S-CX6.4.0 software image. Then reboot
Oracle® Enterprise Session Border Controller2.
ORACLE2# reboot -------------------------------------------------------- WARNING: you are about to reboot this SD! -------------------------------------------------------- Reboot this SD [y/n]?: y
Rebooting Oracle® Enterprise Session Border Controller2 causes Oracle® Enterprise Session Border Controller1 to become the active system in the HA node.
When
Oracle® Enterprise Session Border Controller2 is finished rebooting, use the ACLI
show health command to confirm that it is in the standby state.
If you need to revert to older image, use the HA Backout Procedure.
