Translation Rules for Replacing Strings
To create a translation rule that replaces a string:
A string replacement involves deleting a string followed by adding a string in the removed string’s place. The index is not used when replacing a string.- Enter a descriptive name for this translation in the ID field.
- Enter the string you want to delete in the delete string field.
- Enter the string you want to add in the add string field.
