Translation Rules for Adding Strings
To create a translation rule that adds a string:
- Enter a descriptive name for this translation in the ID field.
- Enter the string you want to add in the add string field.
- Enter the index of the string insertion in the add-index parameter. If you want to add a string at the end of an number, enter a dollar-sign $ in the add index field.
