Unreachable OCSR Configuration
The following sample configuration implements DISA/DoD-compliant client behavior in the event of an unreachable OCSR.
ACMEPACKET# configure terminal
ACMEPACKET(configure)# security#
ACMEPACKET(security)# tls-profile
ACMEPACKET(security)# show
tls-profile
name DoD
end-entity-certificate sylarCert-2048
trusted-ca-certificates dod1 dod2 disaA disaB IBM1
cipher-list all
verify-depth 10
mutual-authenticate disabled
tls-version tlsv1
cert-status-check enabled
cert-status-profile-list DoD
ignore-dead-responder enabled
ACMEPACKET(tls-profile)#
