Create the Acme Packet Boot Media
Before you can perform a system recovery by reinstalling the software image from a USB flash drive, you must prepare the flash drive with the Acme Packet Boot Media Creator.
- Download the zip file for the release that you want from the My Oracle Support website at https://support.oracle.com to a Microsoft Windows PC and confirm that it contains nn<RELEASE>-img-usb.exe.
- This procedure requires a 2-16GB USB flash drive.
To prepare the USB flash drive, launch the Acme Packet Boot Media Creator, add the software image file, and select the boot options. The Acme Packet Boot Media Creator validates the software image file and prepares the USB flash drive to boot the session border controller.
Reinstall the software image on the session border controller. See "Restore the System from a USB Flash Drive."
