Licenses
Oracle® Enterprise Session Border Controller licenses are based the serial number located in the software download file and a license key that you must request from Oracle. You can add additional licenses, for example, for additional feature groups in the same way.
Procedure
- In the software file, locate the serial number by using the show version boot command. The serial number is displayed under Oracle Serial Number.
- Go to http://www.oracle.com/us/support/licensecodes/index.html and request a license key.
- Add your license using the add command in Configuration mode.
- Verify your license using the show features command in Privileged mode.
