PreviousNextJavaScript must be enabled to correctly display this content
Import and Export the E-SBC Configuration
You can import and export the
Oracle® Enterprise Session Border Controller (E-SBC) configuration to and from a Comma Separated Value (CSV) file with the Import Export SPL plug-in. The Import Export SPL plug-in is enabled by default. No configuration is required.
