Synchronize SPL Plug-in Files Across an HA Pair
In a High Availability (HA) configuration, both the active and the standby systems require the same version of the SBC Programming Language (SPL) plug-in script.
There is no means to synchronize SPL files automatically during a save and activate after you add SPL files to the configuration. To configure the standby system, execute the synchronize spl ACLI command. Note that the system only executes the synchronize spl command from the active system in a HA pair.
To copy all files in the /code/spl directory from the active system to the same directory on the standby do not include any arguments. Note that this procedure overwrites any existing files on the standby system with the same name.
To copy individual files, add the specific filename as an argument to the synchronize spl command, for example,
ACMEPACKET#synchronize spl MediaPlayback.1.0.spl ACMEPACKET#synchronize spl LyncEmergencyCall.1.0.spl ACMEPACKET#synchronize spl SipHeaderExtensionMetadata.1.2.spl ACMEPACKET#synchronize spl UniversalCallId.1.spl ACMEPACKET#synchronize spl ComfortNoiseGeneration.1.1.spl
Procedure
- In Superuser mode, type synchronize spl, and press Enter.
ACMEPACKET# synchronize spl
