Alarm Thresholds Configuration
To configure alarm thresholds:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal -
Type system and press Enter to access the system-level configuration elements.
ORACLE(configure)# system -
Type system-config and press Enter.
ORACLE(system)# system-config ORACLE(system-config)#
Type alarm-threshold and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(system-config)# alarm-threshold ORACLE(alarm-threshold)#
type — Enter the type of resource which this alarm monitors. Valid values include:
cpu
memory
sessions
space
deny-allocation
- volume — Enter the logical disk volume this alarm monitors (used only in conjunction when type = space).
severity — Set the severity of the threshold. Valid values include:
minor
major
critical
- value — Enter the value from 1 to 99, indicating the percentage, which when exceeded generates an alarm.
- Save and activate your configuration.
