TCP Port Configuration
To configure media over TCP:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-level configuration elements.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
media-manager and press Enter to begin configuring media over TCP.
ORACLE(media-manager)# media-manager ORACLE(media-manager-config)#
tcp-number-of-ports-per-flow—Enter the number of ports, inclusive of the server port, to use for media over TCP. The total number of supported flows is this value minus one. The default is
2. The valid range is:
Minimum—2
Maximum—5
ORACLE(realm-config)# tcp-number-of-ports-per-flow 5
tcp-initial-guard-timer—Enter the maximum time in seconds allowed to elapse between the initial SYN packet and the next packet in a media-over-TCP flow. The default is
300. The valid range is:
Minimum—0
Maximum—999999999
ORACLE(realm-config)# tcp-initial-guard-timer 300
tcp-subsq-guard-timer—Enter the maximum time in seconds allowed to elapse between all subsequent sequential media-over-TPC packets. The default is
300.
Minimum—0
Maximum—999999999
ORACLE(realm-config)# tcp-subsq-guard-timer 300
tcp-flow-time-limit—Enter the maximum time in seconds that a media-over-TCP flow can last. The default is
86400. The valid range is:
Minimum—0
Maximum—999999999
ORACLE(realm-config)# tcp-flow-time-limit 86400
