Media Profiles Per Realm
For different codecs and media types, you can set up customized media profiles that serve the following purposes:
- Police media values
- Define media bandwidth policies
- Support H.323 slow-start to fast-start interworking
You can use media policies globally for the Oracle® Enterprise Session Border Controller, or—starting with Release C6.1.0—you can configure them for application on a per-realm basis. For a realm, you can configure a list of media profiles you want applied. The Oracle® Enterprise Session Border Controllermatches the value you set for the match-media-profiles parameter, and then applies those media profiles to the realm itself and to all of its child realms (but not to its parent realms).
This feature has no impact on the ways the Oracle® Enterprise Session Border Controller uses media profiles non-realm applications such as: H.323 interfaces, SIP interfaces, IWF, session agents, codec policies, and policy attributes.
