Configuring DNS ALG Service
This section tells you how to access and set the values you need depending on the configuration mechanism you choose. It also provides sample configurations for your reference.
Configuring DNS ALG service requires that you carry out two main procedures:
- Setting the name, realm, and DNS service IP interfaces
- Setting the appropriate parameters for DNS servers to use in other realms
