Realm
To configure SIP number normalization for a realm:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
media-manager and press Enter to access the media-level configuration elements.
ORACLE(configure)# media-manager ORACLE(media-manager)#
Type
realm-config
and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(media-manager)# realm-config ORACLE(realm-config)#
You can either add SIP number normalization support to a new session agent configuration or to an existing session agent configuration:
For a new realm configuration, add the option by typing options, a Space, and then number-normalization.
ORACLE(realm-config)# options number-normalization
For an existing realm configuration without any options already configured, select the realm, type options followed by a Space, and then number-normalization.
ORACLE(realm-config)# select ORACLE(realm-config)# options number-normalization
For an existing realm configuration with other options, select the realm, type options followed by a Space, the plus sign (+), and the number-normalization option.
ORACLE(realm-config)# select ORACLE(realm-config)# options +number-normalization
- Save your work using the ACLI save or done command.
