Session Agent
To configure SIP number normalization for a session agent:
In Superuser mode, type
configure terminal and press Enter.
ORACLE# configure terminal
Type
session-router and press Enter to access the media-level configuration elements.
ORACLE(configure)# session-router ORACLE(session-router)#
Type
session-agent and press Enter. The system prompt changes to let you know that you can begin configuring individual parameters.
ORACLE(session-router)# session-agent ORACLE(session-agent)#
You can either add SIP number normalization support to a new session agent configuration or to an existing session agent configuration:
For a new a session agent configuration, add the option by typing options, a Space, and then number-normalization.
ORACLE(session-agent)# options number-normalization
For an existing session agent configuration without any options already configured, select the session agent, type options followed by a Space, and then number-normalization.
ORACLE(session-agent)# select ORACLE(session-agent)# options number-normalization
For an existing session agent configuration with other options, select the session agent, type options followed by a Space, the plus sign (+), and the number-normalization option.
ORACLE(session-agent)# select ORACLE(session-agent)# options +number-normalization
- Save your work using the ACLI save or done command.
