Set TDM Configuration Wizard
The Set TDM Configuration wizard is a tool that you use to complete the Time Division Multiplexing (TDM) configuration after you create the tdm-object. The wizard completes the configuration by creating the realm, SIP interface, steering pools, and other necessary configuration elements including the network interface and the phy-interface for SIP call routing. If you have an SRTP license, the wizard also creates the media-sec-policy object, enables the secured-network attribute for the sip-interface object, and configures the media-sec-policy attribute for realm-config. You can run the wizard from either the Web GUI or the ACLI.
The Oracle® Enterprise Session Border Controller (E-SBC) requires running the Set TDM Configuration wizard only after the initial TDM configuration. The system does not require you to run the wizard after you make changes to the existing configuration.
When the Oracle Session Delivery Manager (SDM) manages the E-SBC, you configure TDM from the SDM and you do not need to run the Set TDM Configuration wizard. See "TDM Settings on the Session Delivery Manager" for the required settings.The following sections describe the system behavior from the Web GUI and from the ACLI.
ACLI
When you configure the tdm-config object from the ACLI, use the
#setup tdm command to run the wizard. The wizard finishes the configuration and displays a success message upon successful completion or an error message if the completion is unsuccessful.
The following illustration shows an example of the ACLI display after running the wizard on a system with an SRTP license.
codec-policy
name e1CodecPolicy
allow-codecs *
add-codecs-on-egress PCMA
codec-policy
name t1CodecPolicy
allow-codecs *
add-codecs-on-egress PCMU
media-sec-policy
name tdmMediaSec
network-interface
name tdm_p0
ip-address 203.0.113.1
netmask 255.255.255.0
gateway 203.0.113.2
phy-interface
name tdm_p0
operation-type Media
slot 2
realm-config
identifier tdmRealm
network-interfaces tdm_p0:0
media-sec-policy tdmMediaSec
codec-policy t1CodecPolicy
sip-config
sip-interface
realm-id tdmRealm
sip-port
address 203.0.113.1
secured-network enabled
snmp-community
community-name public
ip-addresses 172.30.0.165
steering-pool
start-port 20000
end-port 40000
realm-id tdmRealm
network-interface tdm_p0:0
system-config
default-gateway 172.30.0.1
tdm-config
tdm-profile
name tdm-config-test
web-server-config
The following illustration shows an example of the ACLI display after running the wizard on a system with no SRTP license.
codec-policy
name e1CodecPolicy
allow-codecs *
codec-policy
name t1CodecPolicy
allow-codecs *
network-interface
name tdm_p0
gateway 203.0.113.2
phy-interface
name tdm_p0
slot 2
realm-config
identifier tdmRealm
sip-config
sip-interface
realm-id tdmRealm
sip-port
address 203.0.113.1
steering-pool
start-port 20000
end-port 40000
realm-id tdmRealm
system-config
tdm-config
tdm-profile
web-server-config
