TDM Settings on the Session Delivery Manager
In a deployment where the Oracle® Enterprise Session Border Controller (E-SBC) is managed by the Session Delivery Manager (SDM), and you want to use Time Division Multiplexing (TDM), configure TDM on the SDM with the following settings.
With an SRTP License
Use the following settings for TDM when you own an SRTP License.
codec-policy
name e1CodecPolicy
allow-codecs *
add-codecs-on-egress PCMA
codec-policy
name t1CodecPolicy
allow-codecs *
add-codecs-on-egress PCMU
media-sec-policy
name tdmMediaSec
network-interface
name tdm_p0
ip-address 203.0.113.1
netmask 255.255.255.0
gateway 203.0.113.2
phy-interface
name tdm_p0
operation-type Media
slot 2
realm-config
identifier tdmRealm
network-interfaces tdm_p0:0
media-sec-policy tdmMediaSec
codec-policy t1CodecPolicy
sip-config
sip-interface
realm-id tdmRealm
sip-port
address 203.0.113.1
secured-network enabled
snmp-community
community-name public
ip-addresses 172.30.0.165
steering-pool
start-port 20000
end-port 40000
realm-id tdmRealm
network-interface tdm_p0:0
system-config
default-gateway 172.30.0.1
tdm-config
tdm-profile
name tdm-config-test
web-server-config
With No SRTP License
Use the following settings for TDM when you do not own an SRTP License.
codec-policy
name e1CodecPolicy
allow-codecs *
codec-policy
name t1CodecPolicy
allow-codecs *
network-interface
name tdm_p0
gateway 203.0.113.2
phy-interface
name tdm_p0
slot 2
realm-config
identifier tdmRealm
sip-config
sip-interface
realm-id tdmRealm
sip-port
address 203.0.113.1
steering-pool
start-port 20000
end-port 40000
realm-id tdmRealm
system-config
tdm-config
tdm-profile
web-server-config
