Configure Time Division Multiplexing
To perform Time Division Multiplexing (TDM) operations, the
Oracle® Enterprise Session Border Controller (E-SBC) requires a profile that specifies the TDM interface. After you create the profile, you must run either the Set TDM Wizard from the Web GUI or the
setup tdm command from the ACLI to complete the configuration.
- Confirm that the ESBC contains the optional TDM card.
- If you want to enable TDM logging in this procedure, you must enable system logging before you begin.
- If the E-SBC contains the optional Quad-Span card, determine the number of spans that you plan to use.
Use the tdm-config element to configure the TDM profile. The line mode that you specify dictates certain corresponding settings, as noted. For example, when you specify the T1 line mode you must specify ESF for the Framing Value. Do not specify an E1 value for the T1 line mode or a T1 value for the E1 line mode.
- Configure the inbound and outbound TDM local policies.
