View Advanced Logging Status - Command Line View the status of advanced logging to see its state, configuration criteria, and count data. Procedure From the AdvancedLogging.lua SPL-plugin, run the spl show sip advanced-logging command. The system displays the following information. State Log Label Rate Limit Matching Criteria Match Count Logged Count
