Clear Advanced Logging Criteria - Command Line
Use this procedure to clear the advanced logging conditions that were configured from the command line. This procedure clears all conditions and returns the system to the default state, in which all requests are matched.
From the AdvancedLogging.lua SPL-plugin, run the
spl set sip advanced-logging clear-matchingcommand.
