PreviousNextJavaScript must be enabled to correctly display this content
FAX Scenario 3
The following ingress and egress policies are used for this FAX scenario.
Ingress Policy
Egress Policy
allow-codecs
allow-codecs
add-codecs-on-egress
PCMU, G729 ,T.38
order-codecs
order-codecs
force-ptime
disabled
force-ptime
disabled
packetization-time
packetization-time
In the following diagram, PCMU and telephone-event codecs are received by
Oracle® Enterprise Session Border Controller .The egress codec policy has PCMU, G729 and T.38
add-codecs-on-egress.
Since there is a faxable codec in the SDP offer and T.38 in
add-on-egress, the non-faxable codec G729 is stripped and T.38 is added to egress offer.
In the A0 answer the audio m-line is zero indicating disabled and the port for the image m-line is non-zero (20000) so the called party has selected T.38. Hence PCMU in realm A is transcoded to T.38 in realm B.
In the following diagram, PCMU and T38 are received by the
Oracle® Enterprise Session Border Controller. The egress codec policy has PCMU, G729, and T.38
T.38 is present in the O0 offer, and therefore will not be explicitly added by the egress codec policy to the O2 Offer. The logic to remove non-faxable codecs is only invoked when T.38 is added by the
add-codecs-on-egress parameter. In this example, T.38 is not added since is already present in SDP. With PCMU and T.38 received, G729 as a non-faxable codec is not removed. Therefore, PCMU, T.38, and G729 are all present in the O2 SDP offer sent to the answerer.
In the A0 answer, the audio m-line port is 0 indicating that audio is disabled, and the port for the image m-line is nonzero (20000), thus the called party has selected T.38. In the A1 answer the OCSBC send the audio m-line port as 0 indicating that audio is disabled, and the port for the image m-line is nonzero (20000). This set-up results in a non-transcoded T.38 -OCSBC -T.38 fax call.
