PreviousNextJavaScript must be enabled to correctly display this content
FAX Scenario 2
The following ingress and egress policies are used for this FAX scenario.
Ingress Policy
Egress Policy
allow-codecs
allow-codecs
add-codecs-on-egress
G711FB
order-codecs
order-codecs
force-ptime
disabled
force-ptime
disabled
packetization-time
packetization-time
In the following diagram, T.38 is offered to the Oracle® Enterprise Session Border Controller. A second m= line was added to O1 that included a G711FB codec (PCMU).
The SDP answer agreed to PCMU, but disabled T.38. When the Oracle® Enterprise Session Border Controller forwarded the SDP in A1 to the answerer, it stripped the second m= line. Because A1 rejects T.38 m= line, but accepts the PCMU m= line, FAX transcoding is enabled.
The SDP answer agreed to PCMU and T.38. Because both O1 and A1 support T.38, the call proceeds without transcoding.
