PreviousNextJavaScript must be enabled to correctly display this content
Specifying the LRT Location
After moving the DID-range-based LRT to the /code/lrt directory on the
ESD, use the following procedure to specify the file’s location, and the lookup
method.
Specify the look-up type. For DID-based LRTs, enable
string-lookup to ensure that all ranges,
including those with an alphabetic prefix (for example, test123), are properly
evaluated.
