PreviousNextJavaScript must be enabled to correctly display this content
Enabling LRT Usage
You enable LRT usage by assigning it to the local policy attributes.
When enabling usage of a DID-range-based LRT, you need not specify
a match-mode, as required for E164- or string-based LRTs. The match-mode
parameter is ignored for DID LRTs.
Move to local-policy-attributes configuration mode.
