PreviousNextJavaScript must be enabled to correctly display this content
QoS Measurement
This chapter provides detailed information about when to configure the
qos-enable parameter. If you are not using QoS or a QoS-capable
Oracle® Enterprise Session Border Controller, then you can leave this parameter set to disabled (default).
