Configure the P-Certificate-Subject-Common-Name From the ACLI
Use the following procedure to configure the P-Certificate-Subject-Common-Name.
To configure the P-Certificate-Subject-Common-Name:
In Superuser mode, type
configure terminal, and press Enter.
ORACLE# configure terminal ORACLE(configure)#
Type
session-router,
and press Enter.
ORACLE(configure)# session-router ORACLE(session-router)#
Type enforcement-profile, and press Enter.
ORACLE(session-router)# enforcement-profile ORACLE(enforcement-profile)#
add-certificate-info—Enter sub-common name for the certificate attribute names to enable TLS certificate information caching, and for the inserting of cached certificate information into customized SIP INVITEs. Default is blank. Valid values are:
sub-common name
sub-alt-name-DNS
certificate-ruri-check—Enable this parameter if you want your
Oracle® Enterprise Session Border Controller to cache TLS certificate information and use it to validate Request-URIs. Enabling this parameter allows the Net- Net ESD to cache the TLS certificate information in a customized SIP INVITE. Default is disabled. Valid values are:
enabled
disabled
verify-certificate-info-register —Select whether or not to allow the
Oracle® Enterprise Session Border Controller to add certificate information to the header of a REGISTER message for verifying a ruri against certificate attributes. Default is disabled. Valid values are:
enabled
disabled
Type
done, and press Enter.
ORACLE(enforcement-profile)# done ORACLE(enforcement-profile)#
Type
exit, and press Enter.
ORACLE(enforcement-profile)# exit ORACLE(session-router)#
- Save the configuration.
