Before You Begin
The Oracle ILOM Remote System Console (Plus), available from the SP web interface, provides remote redirection for the following devices: keyboard, video, mouse, and storage.
As an alternative method for redirecting storage devices in Oracle ILOM, you can use the Oracle ILOM Storage Redirection CLI. To locate instructions on how to use this feature, refer the Related Information section following this procedure.
You need the Console (c) role privileges to operate the Oracle ILOM Remote System Console (Plus).
Java 7 update 131 or later must be installed. TLS 1.1 and 1.2 must be enabled in the Advanced Settings of the Java Control Panel.
To launch the Oracle ILOM graphical remote console from the SP web interface:
For best performance, absolute mode is typically selected for Oracle Solaris–based operating systems, and relative mode is selected for Linux-based operating systems.
Tip – To toggle the keyboard or mouse input between the managed server and the local desktop, press: Alt+m (for mouse) or Alt+k (for keyboard).
