Skip Headers
Oracle® Retail Integration Bus Installation Guide
Release 13.1
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
D Integration Gateway Services .ear File Installation
This section provides detailed steps for installing the Integration Gateway Services (IGS) .ear file. The instructions below cover the following topics:
  1. Prerequisites
  2. Preparing the WebLogic Server (WLS)
  3. Deploying the IGS .ear file
  4. Testing the IGS using the WLS test page
Prerequisites
Installation of the IGS .ear file requires the following:
Each .ear file or ejb-jar file containing the services should be deployed on its own WebLogic instance.
To avoid confusion when naming the WebLogic instance, it is recommended that the .ear file name is used (without the extension) along with underscore, wls_instance. For example, if the .ear file is rms-service.ear, the instance name is rms-service_wls_instance.
Before deploying the IGS .ear file, be sure to create RIB AQ JMS Topics. For information, see Chapter 4, "Run the RIB Application Installer."
Prepare the WebLogic Server
Create a datasource for IGS, pointing to the RIB AQ JMS server, as follows:
  1. Navigate to the Summary of JDBC Data Sources screen using the Services > JDBC > Data Sources menu.
    Surrounding text describes app_d_1.png.
  2. Click New to open the Create a New JDBC Data Source screen. Enter the following values:
    Field Name Value
    Name
    igs-ojms-managed-datasource
    JNDI Name
    IGSOracleAQJmsDs
    Database Type
    Oracle
    Database Driver
    Oracle
    Surrounding text describes app_d_2.png.
  3. Also on the Create a New JDBC Data Source screen, uncheck "Supports Global Transactions."
    Surrounding text describes app_d_3.png.
  4. Also on the Create a New JDBC Data Source screen, enter the following database details:
    • Database Name
    • Host Name
    • Port
    • Database User Name
    • Password
    • Confirm Password
    Surrounding text describes app_d_4.png.
  5. Also on the Create a New JDBC Data Source screen, verify the configuration details, as shown below:
    Surrounding text describes app_d_5.png.
  6. At the top of the screen, click Test Configuration to ensure the server is able to connect to the database. Note the message at the top of the following screen: "Connection test succeeded."
    Surrounding text describes app_d_6.png.
  7. Also on the Create a New JDBC Data Source screen, select the target server under Select Targets. Click Finish.
    Surrounding text describes app_d_7.png.
  8. Upon clicking Finish, the newly created data source should appear in the list of data sources (on the Summary of JDBC Data Sources screen).
    Surrounding text describes app_d_8.png.
Deploy the IGS .ear File
Complete the following steps to deploy the IGS .ear file.
  1. Download the IntegrationGatewayService13.1.0ForAll13.1.0Apps.tar to a temporary location.
  2. Run the following command for extracting the contents of the .tar file:
    $ tar -xvf IntegrationGatewayService13.1.0ForAll13.1.0Apps_eng-ga.tar
  3. Navigate to the "integration-bus-gateway-services" directory to see the contents:
    $ cd integration-bus-gateway-services
    $ ls -ltr
    Surrounding text describes app_d_9.png.
  4. Navigate to the WL_Server > Deployments screen to view the list of deployed applications on the Summary of Deployments screen.
    To re-deploy an application that is already deployed, click Delete first to "undeploy" the application. Then continue with the following steps.
    Surrounding text describes app_d_10.png.
  5. On the Summary of Deployments screen, click Install to open the Install Application Assistant screen.
    Surrounding text describes app_d_11.png.
  6. On the Install Application Assistant screen, click the "upload your file(s)" link to display the Deployment Archive field.
    Surrounding text describes app_d_12.png.
  7. In the Deployment Archive field enter the .ear file location of the local server, as shown below:
    Surrounding text describes app_d_13.png.
  8. Click Next to view the following portion of the Install Application Assistant screen:
    Surrounding text describes app_d_14.png.
  9. Click Next to move on to the portion of the Install Application Assistant screen shown below. Click the "Install this deployment as an application" radio button.
    Surrounding text describes app_d_15.png.
  10. Click Next to display a list of Optional Settings. Leave the default values as they are shown below:
    Surrounding text describes app_d_16.png.
  11. Click Next to view the following portion of the Install Application Assistant screen. Select the "No, I will review the configuration late" radio button.
    Surrounding text describes app_d_17.png.
  12. Click Finish to start the deployment process and return to the list of deployed applications.
Test the IGS using the WLS Test Page
Clicking Finish in the last set of instructions opens the Deployments screen shown below. Each application has a link to all of its modules and components.
Surrounding text describes app_d_18.png.
  1. In the list of applications, click on the plus sign (+) beside integrations-service to display the modules and components associated with it.
    Surrounding text describes app_d_19.png.
  2. Under Modules and Components, click on any Web service to view a list of Web service details, as shown below.
    Surrounding text describes app_d_20.png.
  3. In the Settings for AllocPublishingService screen, click the Testing tab.
    Surrounding text describes app_d_21.png.
  4. Click the Test Client link to open the Web service test client page:
    Surrounding text describes app_d_22.png.
  5. Modify the SOAP request body as needed. Click on the method required to invoke the corresponding method of the Web service. Once the method call is complete, the SOAP response will display in the same page.
