This appendix provides a guideline for the order in which the Oracle Retail applications should be installed. If a retailer has chosen to use only some of the applications, the order is still valid--less the applications not being installed.
Note: The installation order is not meant to imply integration between products. |
Oracle Retail Merchandising System (RMS), Oracle Retail Trade Management (RTM), Oracle Retail Sales Audit (ReSA)
Oracle Retail Service Layer (RSL)
Oracle Retail Extract, Transform, Load (RETL)
Oracle Retail Active Retail Intelligence (ARI)
Oracle Retail Warehouse Management System (RWMS)
Oracle Retail Allocation
Oracle Retail Invoice Matching (ReIM)
Oracle Retail Price Management (RPM)
Note: During installation of RPM, you are asked for the RIBforRPM provider URL. Because RIB is installed after RPM, make a note of the URL you enter. If you need to change the RIBforRPM provider URL after you install RIB, you can do so by editing the jndi_provider.xml file. |
Oracle Retail Central Office (ORCO)
Oracle Retail Back Office (ORBO) or Back Office with Labels and Tags (ORLAT)
Oracle Retail Store Inventory Management (SIM)
Oracle Retail Predictive Application Server (RPAS)
Oracle Retail Merchandise Financial Planning (MFP)
Oracle Retail Size Profile Optimization (SPO)
Oracle Retail Assortment Planning (AP)
Oracle Retail Item Planning (IP)
Oracle Retail Item Planning configured for COE (IPCOE)
Oracle Retail Integration Bus (RIB)
Oracle Retail Point-of-Service (ORPOS)
Orace Retail Mobile Point-of-Service (ORMPOS)
Oracle Retail Analytics Applications
Oracle Retail Data Warehouse (RDW)
Oracle Retail Workspace (ORW)
