The RIB Application Builder and its directories and content are not a temporary staging structure. The directory structure and the tools must be in a permanent location and treated as a core application home. The location of the rib-app-builder is a key implementation decision.
Note: See "Pre-Implementation Considerations" in the Oracle Integration Bus Implementation Guide. |
The RIB installation process builds and executes out of rib-home. The RIB installer gathers all of the information that these tools require, constructs the key XML file (rib-deployment-env-info.xml), and then performs the installation, assembly, configuration, and deployment by invoking, as appropriate, a given task. Therefore, for most RIB software life cycle activities, the RIB installer should be used instead of the command line tools.
The rib-<app> application configuration and installation process follows the RIB lifecycle phases. Each of the lifecycle phases can be managed by a certain role. To support the separation of roles and responsibilities and to clearly define these phases, RIB has adopted a specific directory structure. The tools required for each of these roles are provided within this directory structure.
This directory structure supports access permissions to different tools that are managed according to the site-specific business requirements. For example, a systems administrator can be given access permissions to all the tools, while a RIB administrator or applications administrator can be provided access to only certain operation tools.
The RIB Application Builder directory structure is fixed and is created by the RIB kernel tar file: RibKernel<release>ForAll<release>Apps_eng_ga.tar.
The rib-home is a controlled structure and there are very specific rules for using the tools and the key files with in it. A key rule is that the tools scan and check versions of all files within rib-home (except for tools-home). The processes do not allow files to have the same name with only an additional extension.
The following is not allowed: rib-rms.properties.bak
rib-home
rib-installer.sh -- this is the RIB GUI Installer
.retail-installer -- this directory contains the RIB GUI installer file
application-assembly-home
bin
rib-app-compiler.sh
select-deployment-options.sh
conf
log
rib-aip
rib-func-artifacts
rib-func-artifact-<version>.war
rib-private-tafr-business-impl-<version>.jar
retail-public-payload-java-beans-base-<version>.jar
retail-public-payload-database-object-types-<version>.jar
retail-public-payload-database-xml-library-<version>.jar
retail-public-payload-java-beans-<version>.jar
retail-public-payload-xml-samples-<version>.jar
rib-rms
rib-<app>-adapters-resources.properties
rib-<app>-adapters.xml
rib-<app>-plsql-api.xml
rib-<app>.properties
rib-rpm
rib-rfm
rib-rwms
rib-sim
rib-tafr
rib-oms
rib-rxm
rib-ext
deployment-home
bin
rib-app-deployer.sh
conf
log
download-home
all-rib-apps
all-rib-defect-fixes
bin
check-version-and-unpack.sh
log
rib-func-artifacts
integration-lib
internal-build
third-party
maintenance-home
bin
check-version-and-apply-defect-fix.sh
inventory-management.sh
inventory-reports.sh
setup-security-credential.sh
history-repository
rib-inventory-info.xml
log
operation-home
bin
rib-adapter-controller.sh
log
tools-home
javaee-api-stubs
plsql-api-stubs
integration-bus-gateway-services
rdmt
rib-func-artifact-gen
riha
All RIB Application Builder tools use the rib-deployment-env-info.xml as the source of all values.
Logging is done for each tool with a log directory, where the execution log is maintained (for example, rib-app-builder.compiler.log). These logs are maintained by log4j2 and the log4j2.xml in rib-home. Do not edit this log4j2.xml. It is set for DEBUG when the tools are executed by command line. When the RIB installer is used, it displays the logging at the console level as INFO, but the tools themselves write the logs at DEBUG.
The rib-app-builder tools automatically generate a backup when a patch is installed. It is recommended that each site develop a backup plan to include a regular backup at the file system level of the rib-app-builder directory structure.
The rib-compiler is a tool that drives the rib-<app>.ear creation process. It performs validation of the input XML files. The following XML files are used to build the rib-<app>.ear.
rib-integration-flows.xml
rib-application-assembly-info.xml
The compiler tool generates the rib-<app> specific application level configuration files, collects the generated files, and packages them to create a deployable rib-<app>.ear file.
This tool works with all applications in scope in the rib-deployment-env-info.xml file.
| Command Line Option | Description |
| -setup-security-credential | This argument must be used when running the rib-app-compiler for the first time. It prompts the user to enter the credentials for each user alias required to install RIB components. It stores the details as credentials in a wallet file inside the rib-home/deployment-home/conf/security/ directory. The credentials are retrieved and used by the deployer when installing RIB components. |
This tool performs operations related to deploying RIB components. It takes a set of command line arguments and values for each function. All functions are driven by the contents of the rib-deployment-env-info.xml.
| -prepare-jms | Prepares the JMS server with RIB JMS topics using the information in rib-deployment-env-info.xml.
The JMS server must be running. See Chapter 6, "JMS Provider Management." |
| -deploy-rib-func-artifact-war | Deploys the rib-func-artifact.war to the Java EE application server defined in rib-deployment-env-info.xml.
The Java EE server must be running. |
| -deploy-rib-app-ear rib-<app> | Deploys the rib-<app>.ear to the Java EE application server defined in rib-deployment-env-info.xml.
| -update-remote-rib-app-config-files rib-<app> | Updates the rib-<app> application level configuration files in the remote server where rib-<app>.ear is or will be deployed.
The remote server information is defined in rib-deployment-env-info.xml. The Java EE server must be running. |
| -undeploy-rib-func-artifact- war |
Undeploys the rib-func-artifact.war from the Java EE application server defined in rib-deployment-env-info.xml.
| -undeploy-rib-app-ear rib-<app> | Undeploys the rib-<app> from the Java EE application server defined in rib-deployment-env-info.xml.
This tool verifies the version compatibility between RIB paks and extracts the files. The extracted files are moved to the appropriate directories under the rib-home.
The version compatibility between RibKernel, RibFuncArtifact and RIBPaks is determined based on the naming conventions used in the tar files and the information in the MANIFEST.mf file inside the kernel tar file.
The RIB infrastructure kernel, RIB functional Pak, and RIB functional artifacts version naming convention should be the same. All should have the same major and minor versions.
For verification, the tool does the following:
Gets the version of the Rib kernel from the MANIFEST.MF file of the RIB kernel tar file. This is the RibKernel<RIB_MAJOR_VERSION>ForAll<RETAIL_APP_VERSION>Apps_eng_ga.tar.
Reads the functional artifact file from rib-home/download-home/ rib-func-artifacts.
Reads the list of all the RIB application packs from the -home/download-home/all-rib-apps directory.
Uses the naming convention to check if the kernel version is the same as the functional artifact version. If the versions are compatible, the tar file is un-tar'd into the rib-home/application-assembly/ rib-func-artifacts directory.
Uses the naming convention to check if the kernel version is the same as the application packs. If the versions are compatible, the tar file is un-tar'd into the rib-home/application-assembly/rib-<app> directory.
RIB has been designed to centrally manage and track the application of defect fixes. The check-version-and-apply-defect-fix tool is responsible for that activity.
All RIB defect fixes are in the form of a zip file (for example, RIB16_Bug1234.zip). The zip file always contains a README.txt file in the format below.
Product : Oracle Retail Integration Bus
Version # : 16.0.030
Defect # : 1234
Date : MM/DD/YYYY
Defects Fixed by this patch:
Resolution:
Files included:
Defect Fix Install Instructions:--------------------------------
The README.txt file contains specific instructions to apply the defect fix. It is always applied to the rib-home and deployed from there. Depending on the type of defect, it may be necessary to migrate the jar to one of the Oracle Retail applications into the appropriate directories.
Take the following steps to apply the defect fixes to the rib-home:
Drop the Defect.zip into /rib-home/download-home/all-rib-defect-fixes directory.
Run the check-version-and-apply-defect-fix.sh script from the /rib-home/maintenance-home/bin directory.
Run the rib-home/application-assembly-home/bin/rib-app-compiler.sh script from the rib-home/application-assembly-home/bin directory.
Run the rib-home/deployment-home/bin/rib-app-deployer.sh script from rib-home/deployment-home/bin directory to deploy the appropriate rib-<app>s.
The tool check-version-and-apply-defect-fix.sh will perform version compatibility checks and will update the RIB inventory XML file.
RIB jars and XML files in rib-home are tracked through an XML file called rib-inventory-info.xml located in the rib-home/maintenance-home/history-repository/ directory. This file is initially created when the RIB installer, or user, executes the check-version-and-unpack tool the first time to extract the RIB application packs and the functional artifacts. Thereafter this file is updated and tracks the file change history of the jars and xml files in the rib-home system.
| -update-current-inventory | Scans the rib-home file system and updates the inventory database. |
| -generate-file-change-history-report | Generates a report of how the files in the rib-home file system have changed over time. |
| -generate-defect-fix-applied-report | Generates a report of what defect fixes have been applied to rib-home on this system. |
| -generate-defect-fix-detail <defect-fix-id> | Displays the long defect resolution description for a given defect fix id. |
The user names and passwords required to install RIB components are stored as security credentials in a wallet file located in the rib-home/deployment-home/conf/security/ directory. The file is initially created when the RIB installer, or user, executes the rib-app-compiler tool with the setup-security-credential argument the first time and enters all the user names and passwords required for installing RIB components. Thereafter, this file can be modified using the setup-security-credential script located in rib-home/maintenance-home/bin directory. After updating existing credentials, the user must run the rib-app-compiler tool again and redeploy RIB applications to use the new credentials.
| -setup-aq-credential <aq-id> | Updates the security credential for the AQ JMS Server ID specified in rib-deployment-env-info.xml |
| -setup-weblogic-credential<wls-id> | Updates security credential for the specified WebLogic instance. |
| -setup-admin-gui-credential rib-<app> | Updates security credential for the RIB Administration GUI users for the specified RIB application. |
| -setup-error-hospital-credential rib-<app> | Updates security credential for the error hospital database user for the specified RIB application. |
| -setup-app-database-credential rib-<app> | Updates security credential for the application database for the specified RIB application. |
| -setup-jndi-credential rib-<app> | Updates security credential for the remote JNDI for the specified RIB application. |
The following HTML reports can be used to verify the successful installation of RIB hot fixes:
defect-fix-applied-report.html
file-change-history-report.html
defect-fix-detail-<defect-fix-id>.html
These reports are available at rib-home/maintenance-home/history-repository/HTML-Report.
Sample: file-change-history-report
Sample: defect-fix-detail-<defect-fix-id>
The rib-adapter-controller provides a set of tools that perform RIB adapter control functions such as start/stop and subscriber check. The command line options and usage are summarized here. For more information, see "RIB Components Start and Stop."
Note: The rib-adapter-controller does not work if the adapters have not been started from the RIB Admin GUI at least once. If the rib-adapter-controller does not work, log in to the RIB Admin GUI and start all adapters. After this initial start, the adapters can be in any status and will respond to rib-adapter-controller commands. |
This function starts all adapters in a message flow for a given family or family list (comma separated list without any space).
start integration-message-flows <family-name-list>[no-subscriber-check]
The function does the following:
For a given family, it identifies all message flow IDs in which this family directly or indirectly participates.
Using the message flow IDs defined in the rib-integration-flows.xml, it connects to all application servers where the respective rib-apps are deployed.
It starts the adapters in the order as defined in the message flows.
It checks if durable subscribers exist before starting an adapter.
It ignores all RIB applications that are not in scope.
Examples:
rib-adapter-controller.sh start integration-message-flows Alloc rib-adapter-controller.sh start integration-message-flows Alloc,Order
This function stops all adapters in a message flow for a given family or family list (comma separated list without any space).
stop integration-message-flows <family-name-list>
Using the message flow IDs in the rib-integration-flows.xml, it connects to all application servers where the respective rib-apps are deployed.
It stops the adapters in the order as defined in the message flows.
It ignores RIB applications that are not in scope.
Examples:
rib-adapter-controller.sh stop integration-message-flows Alloc rib-adapter-controller.sh stop integration-message-flows Alloc,Order
This function lists all adapters in a message flow for a given family or family list (comma separated list without any space).
list integration-message-flows <family-name-list>
It displays all message node IDs for all message flows in which the given family participates.
It lists the adapters in the order as defined in the message flows.
Examples:
rib-adapter-controller.sh list integration-message-flows Alloc rib-adapter-controller.sh list integration-message-flows Alloc,Order
This function starts all adapters by type, given a rib-app or rib-app-list (comma separated list without any space).
start rib-app-adapters-by-type <sub,tafr,pub,hosp_retry,all><rib-app-list> [no-subscriber-check]
For every adapter type specified in the input, it collects the adapter instances from the given rib-app-list.
It re-sorts the input adapter types to start in the correct order.
It connects to the respective applications servers where rib-apps are deployed.
It starts the sub adapters first in all rib-apps and then moves on to start all TAFR adapters in all rib-apps, and so on.
Examples:
rib-adapter-controller.sh start rib-app-adapters-by-type sub,tafr rib-rms rib-adapter-controller.sh start rib-app-adapters-by-type pub,sub rib-rms,rib-sim rib-adapter-controller.sh start rib-app-adapters-by-type all rib-rms,rib-sim
This function stops all adapters by type, given a rib-app or rib-app-list (comma separated list without any space).
stop rib-app-adapters-by-type <sub,tafr,pub,hosp_retry,all><rib-app-list>
It stops the first adapter type first in all rib-apps, and then it moves on to stop the second adapter types in all rib-apps and so on.
Examples:
rib-adapter-controller.sh stop rib-app-adapters-by-type sub,tafr rib-rms,rib-sim rib-adapter-controller.sh stop rib-app-adapters-by-type pub,sub rib-adapter-controller.sh stop rib-app-adapters-by-type all rib-rms,rib-sim
This function starts individual adapter instances. The adapter instance must be fully qualified as rib-<app>.<Family>_<type>_<n>. A comma separated list of adapter instances names can also be provided.
start rib-app-adapter-instance <rib-app.Family_type_1-list>[no-subscriber-check]
Checks if durable subscribers exist before starting an adapter.
Starts the adapter instance.
Examples:
rib-adapter-controller.sh start rib-app-adapter-instance rib-rms.Alloc_pub_1 rib-adapter-controller.sh start rib-app-adapter-instance rib-rms.Alloc_pub_1,rib-sim.ASNIn_sub_1
This function stops individual adapter instances. Adapter instances must be fully qualified as rib-<app>.<Family>_<type>_<n>. A comma separated list of adapter instances names can also be provided.
stop rib-app-adapter-instance <rib-app.Family_type_1-list>
Examples:
rib-adapter-controller.sh stop rib-app-adapter-instance rib-rms.Alloc_pub_1 rib-adapter-controller.sh stop rib-app-adapter-instance rib-rms.Alloc_pub_1,rib-sim.ASNIn_sub_1
This function tests if durable subscribers exist for topics associated with a given adapter class definition. Adapter class definition must be fully qualified as rib-<app>.<Family>_<type>. A comma separated list of adapter class definition names can also be provided.
test durable-subscriber-exist-for-adapter-class-def <rib-app.Family_type-list>
It finds the topic names to which the input RIB application adapter class definition publishes.
For each topic it publishes to, it checks to see if there is a durable subscriber registered.
Examples:
rib-adapter-controller.sh test durable-subscriber-exist-for-adapter-class-def rib-rms.Alloc_pub rib-adapter-controller.sh test durable-subscriber-exist-for-adapter-class-def rib-rms.Alloc_pub,rib-tafr.ASNOutToASNOutAT_tafr
This function tests if durable subscribers exist for all publishing topics associated with a given rib-app or rib-app-list (comma separated list without any spaces).
test durable-subscriber-exist-for-rib-app <rib-app-list>
Finds all adapter instances that publish for the given rib-app-list.
Examples:
rib-adapter-controller.sh test durable-subscriber-exist-for-rib-app rib-rms rib-adapter-controller.sh test durable-subscriber-exist-for-rib-app rib-rms,rib-sim
The rib-adapter-controller lists all adapter instances for a given rib-app or rib-app-list (comma separated list without any spaces).
list rib-app-adapters <rib-app-list>
Examples:
rib-adapter-controller.sh list rib-app-adapters rib-rms rib-adapter-controller.sh list rib-app-adapters rib-rms,rib-sim
The RIB Deployment Configuration File Editor is an application used to configure the rib-deployment-env-info.xml file, following installation. The editor tool simplifies user interaction with the XML file by hiding the raw text form of XML. It provides a user interface for adding, removing, and rearranging the elements of the RIB configuration.
Note: See the "RIB Application Builder Tools" in this chapter and "rib-deployment-env-info.xml" in Chapter 3, "Backend System Administration and Logging." |
The tool is located in the RDMT package and installed with RDMT in the <rib-home>/tools-home/RDMT directory. It is available as a menu selection from the RIB Admin sub menu.
Note: The editor is a GUI application. To execute it on a host other than the one on which RDMT is installed, use an X server, such as Exceed, and set the DISPLAY environment variable. |
All rib-app-builder tools use the rib-deployment-env-info.xml as the single source of truth about the deployment configuration. See "RIB Deployment Configuration File Editor" in Chapter 3, "Backend System Administration and Logging."
All tools use the values in this file. Editing the file directly affects the compilation, configuration, and deployment of the rib-apps. Use extreme caution and understand the ramification of the values being manipulated.
Note: See the Oracle Integration Bus Implementation Guide. |
Before editing the source file in rib-home, make a backup of the file and place it securely outside of rib-home. Do not create a backup in the rib-home.
The following is an illustration of the editor interface.
Note: See the online help provided in the tool for additional details. |
The RIB Deployment Configuration File Editor allows users to do the following:
Add, delete and move applications.
Add, delete and move WebLogic instances.
Add and delete Application Server instances.
Configure JMS servers.
To edit files using the editor, do the following:
Select File from the menu bar. Click Open.
Navigate to the directory containing rib-deployment-env-info.xml.
Select the file and open it.
Complete the required task (for example add, delete, or move).
Save the file using the File menu.
