Underwriting is the next step after application entry in Lease origination cycle. At the beginning of underwriting process, the application has been entered into Oracle Financial Services Lending and Leasing, receiving an application number. The application, then passes through the initial prescreening checks, and receives a credit bureau report. (Credit bureau pulls are based upon zip code setup.) The system assigns it a custom credit score and based on this, the application automatically updates its status and sent to the appropriate queue. In doing so, one of three things happen to the application:
This chapter explains how to use the Underwriting screen to complete the following tasks:
The underwriting process follows these basic steps:
The first step in the underwriting process is to load the application you want to work with. For details about using the Loading an application, refer Searching for an Application in the chapter Search Function.
The Underwriting screen’s Applications section appears at the top of the screen opened from Underwriting master tab. The screen displays the application number and name on the header and contains information such as application purpose, product and producer.
In this section, you can perform any of the Basic Operations mentioned in Navigation chapter
A brief description of the fields is given below:
Field: |
View this: |
App # |
The application number |
Dt |
The application date |
Product |
The Lease product of the application. |
Channel |
How the application information was received. |
Priority |
The priority of the application. |
Company |
The company of the application. |
Branch |
The branch of the company. |
Status |
The status of the application. |
Origination Stage Code |
The origination stage code of the application. |
Billing Cycle |
The billing cycle of the application. |
Purpose |
The purpose of the application. |
Producer |
The producer type and producer of the application. |
Producer Name |
The name of the producer of the application. The Producer Name is displayed as a hyperlink and clicking on the same will open ‘Producers’ page with details of the producer. |
Producer Contact Number |
The system displays the contact number of the producer. |
Region |
The region of the producer. |
Territory |
The territory of the producer. |
Existing Customer |
Indicates if the customer is an existing customer. |
Duplicate Application |
Indicates if the application is a duplicate application. |
Lease Currency |
The Lease currency of the application. |
Class |
The class of the application. |
Sales Agent |
The sales agent of the application. |
Joint |
If selected, indicates this is a joint application. |
Cosigned |
If selected, indicates this is a co-signed application. |
Contact |
The contact of the application. |
Lead # |
The lead number will appear in the list only if a lead is already created using the Sales Lead link. |
CRB Pull |
Check this box to pull an initial credit bureau report, after the application passes the pre screen edits. Uncheck the box, if you want to enter an application without pulling a credit report. To use a previously pulled credit bureau report, uncheck this box and specify the Bureau and Bureau Reorder # fields on the Primary Applicant screen. |
Override Ok |
Check this box to ignore the overrides. If the application has been marked as ‘Override OK’ then the system would allow you to change the application status even when override condition exists. |
Warning Ok |
Check this box to ignore the warnings. If the application has been marked as ‘Warning OK’ then the system would allow you to change the application status even when warning exists. |
Proxy for Underwriter |
If you are acting as a proxy for an Underwriter, then you can select the Underwriter’s name from the adjoining options list. The list displays all the associated Underwriters, Underwriting Supervisors, and Underwriting Managers. However, this is not mandatory and can be used while auctioning an application on behalf of another underwriter. |
You can use underwriting screen’s Applications master screen to change the status and sub status of the application.
To change the status of the application
The system checks the information on the Underwriting form using guidelines established during implementation.
The system finds an error based on these guidelines, a Warning message appears stating “Validation Error exist, Unable to Change the status. Please check the Edits.”
During status change:
During status change, if there is a warning in the edit, the system displays an error message as ‘Warning Exists. Do you want to continue?’.
Once the application moves to status of Approved, Rejected, or conditioned status, you cannot amend the information. However, you can amend the application, by changing the sub status of the application to Rehashing.
To Rehash the Application
After you enter the information required in the application, you can change the status to Approved, Rejected, conditioned, or Withdrawn. (For more information, refer Decision Tab section in this chapter.)
Once the status is changed to Approved, Rejected, conditioned, or Withdrawn, you cannot make further changes to the information on the Decision tab.
The Underwriting screen can be configured so that applications will be moved to a separate queue after a certain amount of time. (This time frame is determined in setup). This applications receive a sub status of Aged Application. This housekeeping function allows you to keep your system free of stagnant application by moving them into an archive.
The summary screen provides a unified view of the application details without navigating to the respective screens/ sub-tabs.
Using this screen, you can view the following details in their respective sections:
To view the Super Summary
The Super Summary tab provides a snapshot of all relevant details in a single screen and contains details of Applicant, Employment, Ratios, Bureau, Requested financials, Decision updates, Contract updates and Primary Collateral details. You need not have to navigate to each of these tabs for specific information on the application. Also clicking on the hyperlinks of Address, Employment, Ratios, and Trade-In helps you to directly navigate to respective tab(s),
During the Underwriting and Funding stages, 'verified' button is displayed just below the address and employment details for each of the applicants. This would be enabled only when the Verified by and Verified Dt in the respective tabs are blank. You can verify the details from the Super Summary tab. Clicking on Verified will do the following:
You need not navigate to Address and Employment tab for verifying applicant details.
Decision details will be displayed when application has Origination Stage as “Review, Decisioned, Contract or Funded”. In case an application is Rehashed, only Decision information will be displayed and Contract information will not be displayed. Contract details will be displayed when application has Origination Stage as “Contract or Funded”.
The system displays the collateral details maintained in the collateral tab on click of navigation button under the headings Primary Collateral and Secondary Collateral. Collateral details for Unsecured loan also will be displayed if they are maintained.
All the trade-in details, if any, maintained in the application would be displayed on click of Navigation button.
Having selected and loaded an application, you can view the information about applicant in the Applicants tab. This is information that was recorded on the Application Entry screen or gathered during the credit pull. You can edit data from the Application Entry screen at anytime in the following steps. Remember to save your work with each change. Information from the credit bureau pull is available to view only.
Using the information supplied on the application, complete the Applicants tab details and the following sub tab details:
Primary Applicant details are required for SME applications also. The system uses information on the Financial and Liabilities sub tabs in determining the applicant’s net worth. The system uses information on the Employments screen and Other Incomes sub screen to calculate the applicant’s debt-to-income ratio.
To verify applicant information on the Underwriting screen
Field |
Do this |
Relation Type |
Select the relationship type from the adjoining drop-down list. For example, primary, spouse, secondary, or cosigner. |
Salutation |
Select the salutation from the adjoining drop-down list. |
First Name |
Specify the applicant’s first name. |
MI |
Specify the applicant’s middle name. |
Last Name |
Specify the applicant’s last name. |
Family Name |
Specify the applicant’s family name. |
Suffix |
Select the name suffix/generation from the adjoining drop-down list. |
Birth Dt |
Specify the applicant’s date of birth. |
SSN |
Specify the applicant’s social security number. |
Class |
Select the classification of the applicant from the adjoining drop-down list. For example, normal or employee. The system uses this information to restrict access to the database by recognizing employees as ‘secured applications’. You can create a SME (Small Medium Enterprise) application by selecting Small business. When you select small business and save your entry, the Business Applicants link on the Applicants link is available. (required). |
Specify the personal Email ID of the applicant. |
Time Zone |
Specify the time zone to which the applicant belongs. This information appears when you enter and save the zip code for the primary applicant’s current home address on the Address sub screen. You can also manually complete this field. |
Identity Information Section |
Nationality |
Select the applicant’s nationality from the adjoining drop-down list. |
National ID |
Specify the national identification number. |
Passport # |
Specify the passport number. |
Passport Issue Dt |
Select the date on which passport was issued. |
Passport Expiry Dt |
Select the passport’s expiration date. |
Visa # |
Specify the applicant’s visa number. |
License # |
Specify the applicant’s license number. |
License State |
Select the state where the license was issued, from the adjoining drop-down list. |
Prior Applicant |
Check this box to indicate that the customer is an existing customer. |
Existing Customer |
Check this box to indicate that this applicant has a previous account. |
Existing Customer ID |
Specify the customer ID if the applicant is an existing customer. |
Existing Customer # |
Specify the customer number if the applicant is an existing customer. On saving the applicant details, the data in ‘Existing Customer #’ is displayed as a link in ‘Applicant’ section header and clicking on the same will display the customer details in Search Results section of Servicing module. |
Update Customer Info |
Check this box to indicate if system can override the existing customer information and create the record with latest address and communication details of the customer. |
Other Details section |
Name in Local Language |
Specify the applicant’s name in local language. |
Gender |
Select the gender of the applicant from the adjoining drop-down list. |
Mother’s Maiden Name |
Specify the mother’s maiden name. |
Education |
Select the education of the applicant from the adjoining drop-down list. |
Language |
Select the applicant’s native language from the adjoining drop-down list. |
Dependents |
Specify the number of dependents. |
Marital Status |
Select the marital status of the applicant from the adjoining drop-down list. |
ECOA |
Select the ECOA (Equal Credit Opportunity Act) code, from the adjoining drop-down list. This defines the various possibilities on who is liable; individual, joint, cosigner and so on. |
Race |
Select the applicant’s race from the adjoining drop-down list. |
Ethnicity |
Select the applicant’s ethnicity from the adjoining drop-down list. This is the information the Home Mortgage Disclosure Act requires to be reported. |
Disability |
Check this box if the application has a disability. |
Privacy Opt Out |
Check this box to indicate that the applicant has elected to refrain from the non-public sharing of information. |
Insurance Opt Out |
Check this box to indicate that the applicant has elected to refrain from insurance related inquiries. |
Marketing Opt Out |
Check this box to indicate that the applicant has elected to refrain from marketing related inquiries. |
Share Credit Opt Out |
Check this box to indicate that the applicant has elected to refrain from financial information and share credit related inquiries. |
Prior Bankruptcy |
Check this box if prior bankruptcy exists. |
Bankruptcy Discharge Dt |
Enter the discharge date of prior bankruptcy (if one exists). |
KYC Section |
Reference # |
Specify the reference number. |
Status |
Select the status of the applicant from the adjoining drop-down list. |
FATCA Section |
Birth Place |
Specify the birth place of the applicant. |
Birth Country |
Select the country of birth of the applicant. |
Permanent US Resident Status |
Check this box if the applicant has permanent US resident status. |
Power of Attorney Section |
Power of Attorney |
Check this box if you hold a power of attorney. |
Holder Name |
Specify the holder name of the power of attorney. |
Address |
Specify the address of the holder. |
Country |
Specify the country of the power of attorney holder. |
Nationality |
Specify the nationality of the power of attorney holder. |
Telephone Number |
Specify the telephone number of the power of attorney holder. |
Military Service - this section can be used to capture applicant’s Active Military Duty details and can be validated with applicant Bureau Details. |
Active Military Duty |
Check this box to indicate if applicant is on Active Military Duty. |
Effective Dt |
Select the date from when the applicant is on Active Military duty using adjoining calendar. |
Order Ref # |
Specify the Order Reference number which indicates the applicant’s Active Military duty service. |
Release Dt |
Select the date from when the applicant was released from Active Military duty using adjoining calendar. |
You can specify more than one address for each applicant, such as a home address, second home address, and vacation home address. However, at least one must be marked as current. Also, only one address can be selected as the mailing address, and that address must be marked as current. Finally, while you can have more than one Home type address, only one can be marked as current.
To complete the Address sub tab
Based on the country chosen in the address tab, the fields for capturing the address will vary.
Field |
Do this |
Address Type |
Select the type of address from the adjoining option list. |
Current |
Check this box if this is a current address. The mailing address must be marked as current. |
Confirmed |
Check this box if the address is the confirmed one |
Mailing |
Check this box if this is the mailing address. Only one address entry can be marked as the mailing address. |
Permission to Call |
Check this box if customer has provided permission to contact through the specified phone number. Atleast one phone number per application should have the permission to call (flagged as 'Y') for the successful pre-qualification of the application. Else, an error message is displayed. |
Country |
Select the country of mailing address from the adjoining drop-down list. |
Address Details section |
Postal Type |
Select the postal address type from the adjoining drop-down list. |
Address # |
Specify the address number of the mailing address |
Street Pre |
Select the street prefix (directional) from the adjoining drop-down list. |
Street Name |
Specify street name. |
Street Type |
Select the street type from the adjoining drop-down list. |
Street Post |
Select the street postfix (directional) from the adjoining drop-down list. |
Apt # |
Specify the apartment number. |
Address Line 1 |
Specify the first address line. |
Address Line 2 |
Specify the second address line. |
Address Line 3 |
Specify the third address line. |
Zip |
Select the zip code from the adjoining drop-down list. For non US country, you have to enter zip code. |
Zip Extn |
Specify the extension of the zip code. |
City |
Specify the city of the mailing address. |
State |
Select the state of the mailing address, from the adjoining drop-down list. |
Phone |
Specify the phone number. |
Additional Information section |
Own / Rent |
Select the ownership type from the adjoining drop-down list. |
Landlord |
Specify the landlord’s name. |
Landlord Phone |
Specify the landlord’s phone number. |
Contact |
Specify the person contacted on behalf of landlord. |
Contact Title |
Specify title of the person contacted on behalf of landlord. |
Contact Phone |
Specify phone number of the person contacted on behalf of landlord. |
Extn |
Specify the extension of the phone of the person contacted on behalf of landlord. |
Census Tract/BNA code |
Specify census tract/BNA (block numbering area). These are defined by the US Census Bureau code. |
MSA Code |
Specify the metropolitan statistical area (MSA) code. These are similar in concept to a zip code, but used mostly on government reports. |
Comment |
Specify a comment. |
Address Rent Mortgage Stated section |
Years |
Specify the stated number of years at residence. |
Months |
Specify the stated number of months at residence. |
Currency |
Select the currency code of payment amount, from the adjoining drop-down list. |
Pmt Amount |
Specify the stated payment amount. |
Frequency |
Specify the stated payment frequency. |
Rent/Mortgage |
The system displays the rent or mortgage amount. |
Address Rent Mortgage Actual section |
Years |
Specify the Actual number of years at residence. |
Months |
Specify the Actual number of months at residence. |
Pmt Amount |
Specify the Actual payment amount. |
Frequency |
Specify the Actual payment frequency. |
Rent/Mortgage |
Verified Section |
Verified By |
The name of the verifier. |
Verified Dt |
The date of verification. |
Use the Employment sub screen to record employment information about the applicant. You can have more than one entry.
To complete the Employments sub tab
Field: |
Do this: |
Current |
Check this box if this is the current employment. |
Type |
Select the address type from the adjoining drop-down list. |
Employer |
Specify the employer’s name. |
Occupation |
Select the occupation from the adjoining drop-down list. |
Title |
Specify the title. |
Department |
Specify the department of the employer. |
Employee ID |
Specify the employee identification. |
Employer Address section |
Country |
Select the country from the adjoining drop-down list. |
Address # |
Specify the building number. |
Address Line 1 |
Address Line 2 |
Zip |
Zip Extn |
Specify the zip code extension. |
City |
Specify the city. |
State |
Select the state from the adjoining drop-down list. |
Phone |
Specify the work phone number. |
Extn |
Specify phone extension. |
Contact |
Specify the person contacted on behalf of the employer. |
Contact Title |
Specify title of the person contacted on behalf of the employer. |
Contact Phone |
Specify phone number of the person contacted on behalf of the employer. |
Contact Extn |
Specify the extension of the phone of the person contacted on behalf of the employer. |
Comment |
Employment Details Stated section |
Years |
Specify the stated number of years with the employer. |
Months |
Specify the stated number of months with the employer. |
Frequency |
Specify the stated income frequency from the adjoining drop-down list. |
Currency |
Select the currency code from the adjoining drop-down list |
Income Amt |
Specify the stated income. |
Salary |
View the salary of the customer. |
Employment Details Actual section |
Years |
Specify the Actual number of years with the employer. |
Months |
Specify the Actual number of months with the employer. |
Frequency |
Specify the Actual income frequency from the adjoining drop-down list. |
Income Amt |
Specify the Actual income. |
Salary |
Verified Section |
Verified By |
Verified Dt |
The Telecoms sub screen only needs to be completed if additional phone numbers exist. If not, this sub screen can be left blank.
To complete the Telecoms sub tab
Field |
Do this |
Type |
Select the telecommunication type from the drop-down list. |
Phone |
Extn |
Specify the phone extension. |
Current |
Check this box if this Telecom number is current. |
Time Zone |
Select the applicant’s time zone from the drop-down list. |
Start Time |
Specify the best time to start the call. |
Period |
Select the time period for the best time to call start time, am or pm, from the drop-down list. |
Best day to call |
Select the preferred day of the week to contact the customer from the drop-down list. |
End Time |
Specify the best time to end the call. |
Period |
Select the time period for the best time to call end time, am or pm, from the drop-down list. |
The system calculates debt ratios in the Ratios section on the Summary sub screen (Applicants link) using the data in the Incomes and Liabilities sections. Information in the Incomes section comes from the Employments sub screen and the Other Incomes sub screen during application entry. The information in the Liabilities section comes from the Address sub screen, the Liabilities sub screen during application entry, and the credit bureau pull.
To View Summary sub tab
Field |
Do this |
What if Pmt Amt |
Specify the payment amount you want to use in the ratios. |
Score |
View the credit score for the application |
Grade |
View the credit grade for the application |
Totals |
Monthly Income- Stated Amt |
The stated monthly income. |
Monthly Debt- Stated Amt |
The stated monthly liability. |
Monthly Income- Actual Amt |
The actual monthly income. |
Monthly Debt- Actual Amt |
The actual monthly liability. |
Assets Amt - Liabilities Amt |
The net worth amount. |
Ratios |
Debt - Stated Before (%) |
The debt amount stated before. |
Debt - Stated After (%) |
The debt amount stated after. |
Debt - Actual Before (%) |
The actual debt amount before. |
Debt - Actual After (%) |
The actual debt amount after. |
Disposable Inc - Stated Before (%) |
The disposable income stated before. |
Disposable Inc - Stated After (%) |
The disposable income stated after. |
Disposable Inc - Actual Before (%) |
The actual disposable income before. |
Disposable Inc - Actual After (%) |
The actual disposable income after. |
Revolving Debt - Stated Before (%) |
The stated revolving debt before. |
Revolving Debt -Stated After (%) |
The stated revolving debt after. |
Revolving Debt - Actual Before (%) |
The actual revolving debt before. |
Revolving Debt - Actual After (%) |
The actual revolving debt after. |
Pmt to Income - Stated Before (%) |
The stated income payment before. |
Pmt to Income - Stated After (%) |
The stated income payment after. |
Pmt to Income - Actual Before (%) |
The actual income payment before. |
Pmt to Income - Actual After (%) |
The actual income payment after. |
Once the payment amount is approved in Decision screen, it will be copied and displayed in the What if Payment field in Summary sub screen.
The system offers powerful tools to the underwriter for analyzing an applicant’s debt-to-income ratios (total of an applicant’s debt obligation divided by that person’s regular income). The system calculates debt ratios in the Ratios section on the Summary sub screen (Applicants link) using the data in the Incomes and Liabilities sections. Information in the Incomes section comes from the Employments sub screen and the Other Incomes sub screen during application entry. The information in the Liabilities section comes from the Address sub screen, the Liabilities sub screen during application entry, and the credit bureau pull.
An underwriter may also add information to the Incomes and Liabilities sections on the Summary sub screen during the underwriting process.
The debt-to-income ratios in the Ratios section can be recalculated by including or excluding information from the Incomes section, Liabilities section and Financials sub screen.
To calculate debt ratios
Field: |
View this: |
Monthly Income (Stated) |
Monthly Income (Actual) |
Monthly Debt (Stated) |
Monthly Debt (Actual) |
Assets |
The assets. |
Liabilities |
The liabilities. |
Net-Worth |
The net-worth. |
Whenever you modify the ‘What If pmt Amt’ field, system automatically calculates the below ratio's:
The Financials sub screen only needs to be completed if financial assets exist on the application. If not, this sub screen can be left blank.
To complete the Financials sub tab
Field |
Do this |
Type |
Select financial type from the drop-down list. For example, liquid assets, retirement assets, and so on. |
Source |
Specify source; for example, stocks, 401K, rent received, and so on. |
Account # |
Specify the account number. |
Currency |
Select the currency code from the drop-down list. |
Lease Currency Amount |
View the Lease currency amount. |
Amount |
Specify amount. |
Include |
Check this box to indicate that the Asset is included. |
Comment |
Specify comment, if any. |
All the liabilities of the applicant that are entered during application entry are displayed in this tab. For example: Rent. In addition, if you need to record additional liabilities for an applicant the same can be done in this tab. Also any liability information of the applicant received through credit pull will be displayed under 'Credit Bureau Data' in Liabilities sub tab.
To complete the Liabilities sub tab
Field |
Do this |
Include |
Check this box to indicate that the liability is included. |
Liability Type |
Select the liability type from the adjoining drop-down list. |
Currency |
Select the currency code from the adjoining drop-down list. |
Amount |
Specify the liability amount. |
Frequency |
Select the frequency from the adjoining drop-down list. |
Account Type |
Specify the account type. |
Account Balance |
Specify the account balance. |
Lease Account Balance |
Comment |
Specify a comment, if any. |
Credit Bureau Data |
Bureau |
View the name of credit Bureau. |
Open Dt |
View the opening date of credit account. |
Pmt Manner |
View the mode of payment. |
Account # |
View the account number. |
Status |
View the current status of credit account. |
Account Type |
View the type of account maintained. |
Creditor's Name |
View the name of the Creditor. |
Subscriber # |
View the Subscriber number. |
ECOA |
View the ECOA (Equal Credit Opportunity Act) code. |
Term |
View the term of credit. |
Credit Limit |
View the total credit limit amount. |
High Balance |
View the high balance amount if any. |
Past Due Amt |
View the total past due amount if any. |
30 |
View the number of delinquency days. |
60 |
90 |
The Other Incomes sub tab only needs to be completed if other incomes exist on the application. If not, this sub screen can be left blank.
To complete the Other Incomes sub tab
Field |
Do this |
Type |
Select the income type from the adjoining drop-down list. Note: In case, the other income of the applicant is from Employment, then the details of Actual Amount specified in the Employments Sub Tab is auto populated. Also if the income is verified in the Employments Sub Tab, then Verified By and Verified Dt details are auto populated. You can also verify the details here using the current system date. |
Currency |
Select the currency from the adjoining drop-down list. |
Stated Amount |
Specify the monthly stated income. |
Frequency |
Select the income frequency from the adjoining drop-down list. |
Lease Currency Amount Stated |
View the Lease currency amount stated. |
Comment |
Include |
By default the include check box is selected indicating that the other income details are included. You can deselect the same if not required. When Include check box is selected system automatically adds the ‘Loan Currency Amount Stated’ and ‘Loan Currency Amount Actual’ details to Applicant > Summary Tab. Also system calculates the DTI and PTI ratio's based on ‘Actual Amount’ specified. |
Actual Amount |
Specify the actual monthly income amount. |
Lease Currency Amount Actual |
View the actual Lease currency amount. |
Verified By |
The Verified By field is auto populated with the logged in user name only after the record has been verified and saved. |
Verified Dt |
You can verify the record by selecting the current system date from the adjoining calendar icon. Note: System displays an error message if any other dates is selected apart from current system date. |
Any manually pulled credit bureau reports can be used to rescore an application.
To manually rescore a credit bureau report
The system displays the new information in the Credit Scores and Parameters sections. This new score automatically appears in the System Recommendation section on the Decision link.
You can view the credit score based on the system’s internal scoring models in Credit Scores sub tab.
To View Credit Scores sub tab
You can view the following details:
Note
If you select No Bureau in the Credit Bureau Report ID field and click Rescore, the best match internal scoring is used for rescoring the applicant without credit bureau report.
Click De-dupe Applicants to display the existing customer details of the applicant. While reviewing the de-dupe results, if the current applicant's credentials are exactly matching with an existing customer record, you can attach the current application to the existing customer. The same can be done by just keying in the customer ID in the applicants tab and clicking save.
In case a particular customer has more than one account, on clicking De-dupe Applicants the system displays only one account in ‘Duplicate’ sub tab. However, you can view all the accounts held by customer in 'Existing accounts' sub tab.
To View duplicate applicant’s details, click Duplicate Applicant sub tab. In this section you can view the duplicate applicant’s details.
Field |
Do this |
Source Type |
View the source type of the duplicate applicant |
Applicant Id/ Cus Id |
View the applicant ID if the source type is applicant and the customer ID if the source type is customer. |
Application # |
View the application number of the existing applicant details for the respective records. |
Days since last application |
View the total number of days elapsed since the last application date. System auto calculates this value as ‘Current system date (minus) Last application date’. |
ID |
View the applicant ID |
First Name |
View the first name of the duplicate applicant |
Middle Name |
View the middle name of the duplicate applicant |
Last Name |
View the last name of the duplicate applicant |
Date of Birth |
View the date of birth of the duplicate applicant |
CIF |
View the CIF no of the duplicate applicant |
SSN # / National ID |
View the national ID or SSN number of the duplicate applicant |
Driving License # |
View the driving license number of the duplicate applicant |
City |
View the city of the duplicate applicant |
State |
View the state of the duplicate applicant |
Zip |
View the zip of the duplicate applicant |
The Existing Account Sub Tab displays the applicant's details, if it has been previously maintained in the system. Also along with the applicant's details, the account number of the applicant is displayed as a hyperlink. Clicking on the hyperlink will display the respective account details through the Customer Service screen of Servicing module.
In case you do not see a hyperlink associated with the account number, then you might have restricted access to the Servicing module. You can request your system administrator to navigate to Setup > User > Access screen, and enable the ‘ACCESS TO SERCOLL UCS CUSTOMER SERVICE TAB’ option in Security Access Definition section available in the 'Screen' tab. For more information, on defining user privileges, refer to ‘3.3.2 Screen’ section in Setup guide.
View the following details:
Field: |
View this: |
Account # |
The account number. |
Title |
The account title. |
Relation |
The customer relationship. |
Product |
The Lease product. |
Payoff Amount |
The payoff amount. |
Amount Due |
The delinquent amount due. |
Oldest Due Dt |
The due date. |
Status |
The account status. |
Company |
The company. |
Branch |
The branch. |
Total Pay Off Amt |
Total Amt Due |
The total due amount. |
You can add tracking attribute information to an application at any time in the underwriting process by using the Tracking Attribute tab.
The Tracking tab enables you to record further information associated with the application. What items you choose to track are setup during implementation.
To track attributes
Field |
Do this |
Sub-Parameter |
View the sub-parameter |
Parameter |
View the parameter. |
Value |
Specify the information about the corresponding Value field. |
While creating an application for an existing customer, you can retrieve and copy the customer details into the new application by using the Customer Search section of the Simple Application Entry screen.
You can modify only the address, employment, financial details and not the demographic and identification details.
To copy the Customer Details
The system locates and displays all the customer details that meet your search criteria in the Search Results section.
Select Reset Criteria at any time to clear the Comparison Operator and Values columns on the Criteria screen.
Oracle Financial Services Lending and Leasing can record SME business related financial information and business partners on the Business section to assist in approving the Lease application during underwriting. The Business Applicant screen is available and contains the following sub screens:
If there are no business information associated with the application, the Business Applicant tab is unavailable.
To complete the Business tab
The Business tab appears on the Underwriting screen.
Field: |
Do this: |
Organization Type |
Select the organization type. |
Business Type |
Select the type of the business. |
Business Name |
Specify the name of the business. |
Legal Name |
Specify the legal name of the business. |
Tax ID |
Specify the tax identification. |
Start Date |
Specify the business start date. |
# of Employees (Cur) |
Specify the current number of employees at the business. |
# of Employees |
Specify the number of employees at the business after financing. |
Contact Person |
Specify the contact person at the business. |
Business Checking Bank |
Specify the bank name of the business’s checking account. |
Bank Acc # |
Specify the bank account number. |
Avg Checking Balance |
Specify the average checking balance. |
# of Locations |
Specify the number of locations of the business. |
Management Since |
Specify the year the current management was established. |
You can enter more than one address for the business.
To complete the Address Sub Tab
Field: |
Do this: |
Address Type |
Select the address type. |
Country |
Select the country. |
Address # |
Own /Lease |
Select the ownership type. |
Comment |
Postal Type |
Street Pre |
Select the street prefix (directional). |
Street Name |
Specify street name |
Street Type |
Select the street type. |
Street Post |
Select the street postfix (directional). |
Apt # |
Address Line 1 |
Address Line 2 |
Zip |
Select the zip code. For non US country, you have to enter zip code. |
Zip Extn |
Specify the zip extension. |
City |
Specify the city. |
State |
Select the state. |
Phone |
The Business tab’s Telecoms sub tab needs to be completed, if additional phone numbers for the business exist. If not, this sub tab can be ignored.
Field: |
Do this: |
Type |
Select the telecommunication type. |
Phone |
Extn |
Current |
If selected, indicates that this is a current telecom. |
The Business tab’s Financials sub screen only needs to be completed if financial assets exist on the application for the business. If not, this sub screen can be left blank.
Field: |
Do this: |
Type |
Select financial type; for example, liquid assets, retirement assets, and so on. |
Source |
Currency |
Select the currency of the asset. |
Amount |
Specify amount. |
The system displays the Lease currency amount |
Comment |
Include |
Check this box to include this record in calculations on the Other Details sub section. |
The Business Applicant link’s Liabilities sub screen only needs to be completed if financial liabilities exist on the application for the business. If not, this sub screen can be left blank.
Field: |
Do this: |
Type |
Select the liability type. |
Currency |
Select the currency. |
Amount |
Frequency |
Select the frequency. |
Account Type |
Lease Currency Account Balances |
The system displays available Lease currency account balance. |
Account Balance |
Comment |
Specify comments, if any. |
Include |
Check this box to include this record in calculations on the Other Details sub screen. |
You can enter more than one partner for the business.
To complete the Partners sub tab
Field: |
Do this: |
First Name |
Specify the partner’s first name. |
MI |
Select the partner’s middle name. |
Last Name |
Specify the partner’s last name. |
Suffix |
Specify the partner’s suffix. |
SSN # |
Specify the partner’s social security number. |
Birth Dt |
Specify the partner’s birth date. |
Birth Place |
Specify the partner’s birth place. |
Title |
Select the partner’s title. |
Ownership (%) |
Specify the percentage of ownership held by the customer. |
Net worth |
Specify the partner’s net worth. |
Gross Income |
Specify the partner’s gross income. |
Language |
Specify the partner’s language. |
Nationality |
Specify the partner’s nationality. |
Country |
Select the partner’s country code. |
Address # |
Specify the partner’s address number. |
Address Line 1 |
Specify the partner’s first address. |
Address Line 2 |
Specify the partner’s second address line. |
Zip |
Select the partner’s zip code. For non-US country, you have to enter zip code. |
Zip Extn |
Specify the partner’s zip extension. |
City |
Specify the partner’s city. |
State |
Select the partner’s state. |
Phone |
Specify the partner’s phone number. |
Extn |
Specify the partner’s phone extension. |
Specify the partner’s email. |
You can enter more than one affiliate for the business.
To complete the Affiliates sub tab
Field: |
Do this: |
Organization Type |
Select the affiliate’s organization type |
Legal Name |
Specify the affiliate’s legal name |
Business Name |
Specify the affiliate’s business name |
Tax ID |
Specify the affiliate’s tax identification |
Ownership (%) |
Specify the affiliate’s percentage of ownership |
# of Employees |
Specify the affiliate’s number of employees |
NAICS CODE |
Specify the affiliate’s North American Industry Classification System code. |
Country |
Select the affiliate’s country code. |
Address # |
Specify the affiliate’s address number. |
Address Line 1 |
Specify the affiliate’s first address line. |
Address Line 2 |
Specify the affiliate’s second address line. |
Zip |
Select the affiliate’s zip code. For non US country, you have to enter zip code. |
Zip Extension |
Specify the affiliate’s zip extension. |
City |
Specify the affiliate’s city. |
State |
Select the affiliate’s state. |
The Other Details sub screen records information regarding monetary amounts associated with the business such as profits, sales, and expenses.
To complete the Other Details sub tab
Field: |
Do this: |
Currency |
Business Type |
Select the type of business. |
Analysis Frequency |
Select the analysis frequency. |
Lease Currency Gross Margin Factor |
The system displays the Lease currency business’s gross margin factor |
Specify the business’s gross margin. |
Organization Type |
Select the type of organization. |
Lease Currency Income |
The system displays the Lease currency business income amount. |
Income |
Specify the business’s income amount. |
Lease Currency Collection Average |
Specify the Lease currency collection average. |
Specify the collection average. |
Lease Currency Proj Coll Avg Annual |
Specify the Lease currency annual projected collection average. |
Proj. Coll.Avg.Annual |
Specify the annual projected collection average. |
Lease Currency Book List |
Specify the Lease currency business booklist. |
Book List |
Specify the business booklist. |
Lease Currency Turn Over |
Specify the Lease currency turnover amount. |
Turn Over |
Specify the turnover amount. |
Lease Currency Capital Amount |
Specify the Lease currency capital amount. |
Capital Amt |
Specify the capital amount. |
Lease Currency Earned Surplus |
Specify the Lease currency earned surplus amount. |
Earned Surplus |
Specify the earned surplus amount. |
Lease Currency Gross Profit |
Specify the Lease currency gross profit amount. |
Gross Profit |
Specify the gross profit amount. |
Lease Currency Net Profit |
Specify the Lease currency net profit amount. |
Net Profit |
Specify the net profit amount. |
Lease Currency Working Capital |
Specify the Lease currency working capital amount. |
Working Capital |
Specify the working capital amount. |
Lease Currency Annual Sales |
Specify the Lease currency annual sales amount. |
Annual Sales |
Specify the annual sales amount. |
Lease Currency Projected Sales |
Specify the Lease currency projected sales amount. |
Projected Sales |
Specify the projected sales amount. |
Lease Currency Equity |
Specify the Lease currency equity amount. |
Equity |
Specify the equity amount. |
Open Delq |
Specify the open delinquency amount. |
Lease Currency Business Expenses |
Specify the Lease currency business expenses amount. |
Business Expenses |
Specify the business expenses amount. |
Lease Currency Personal Expenses |
Specify the Lease currency personal expenses amount. |
Personal Expenses |
Specify the personal expenses amount. |
Lease Currency Total Expenses |
View the Lease currency total expenses amount. |
Total Expenses |
View the total expenses amount. |
Lease Currency Annual Proj Sales Amt |
View the Lease currency annual projected collection amount. |
View the annual projected collection amount. |
Lease Currency Annual Proj Exp Amt |
View the Lease currency annual projected expenses amount. |
View the annual projected expenses amount. |
Lease Currency Current Assets |
Lease currency current assets. |
Current Assets/Liability ratio |
View the current asset to liability ratio. |
Lease Currency Fixed Assets |
View the Lease currency fixed assets. |
Fixed Assets |
View the fixed assets. |
Lease Currency Intangible Assets |
View the Lease currency intangible assets. |
Intangible Assets |
View the intangible assets. |
Lease Currency Current Liabilities |
View the Lease currency current liabilities |
View the current liabilities. |
Lease Currency Long Term Liabilities |
View the Lease currency long term liabilities. |
View the long term liabilities. |
Lease Currency Total Assets |
View the Lease currency total assets |
Total Assets |
View the total asset amount. |
Lease Currency Total Networth |
View the Lease currency total net worth amount. |
Total Net worth |
View the total net worth amount. |
Lease Currency Total Liability |
Lease currency total liability amount. |
Total Liability |
View the total liability amount. |
Debt Net worth Ratio |
View the debt to net worth ratio. |
Title 1-4 |
Signature1-4 |
Specify the signature. |
You can calculate Payment, Interest Rate, Term and Lease Amount using Request tab’s Calculate button. By default, system calculates for monthly repayment term basis. The payment frequency can be changed only in the Underwriting tab during decisioning.
To complete Request section:
A brief description of the fields are given below:
Field |
Do this |
Requested Advance Amt |
Specify the requested advance amount |
Pmt Amt |
Specify the requested payment amount. |
Term |
Specify the requested term (number of payments). |
Requested Rate |
Specify the requested rate of interest. |
Down Pmt% |
Specify the down payment percentage |
Down Pmt |
Specify the down payment amount |
Approx Prc |
Specify the approximate cash price |
Promotion |
Select the promotion type from the drop-down list. |
Balloon Amt |
Specify the balloon amount. |
Signing Dt |
Specify the signing date |
Probable Delivery Dt |
Specify the probable delivery date. |
If you want system to calculate,
The Itemizations sub tab enables you to add or verify any itemized amounts associated with the application. The list of itemizations is determined by the product you select in the master screen during the application entry process. The Itemizations sub screen displays an itemization record of the amount financed, such as the cash price, cash down payment, trade-in, unpaid cash price balance and so on. Information that was entered on the Itemization sub screen during the application entry process will appear in the Requested Amt column. Information that you enter as an underwriter in the Approved Amt column will appear in the Itemizations sub tab on the Underwriting screen.
Application request details need to be essentially entered in the itemization sub tab for pre-screening to be successful. Else, the system displays error and application would not proceed to the next level in work flow. The details of down payment, trade-in, insurance, fees etc. and the total sale price are recorded under itemization.
To add or view itemizations
Field: |
Do this: |
Itemization |
View the itemization. |
View whether the itemized amount is added or subtracted from the Lease amount. |
Requested Amt |
Specify the requested amount. |
Comment |
The Trade-In sub screen enables you to add or verify any trade-ins associated with the application. If there is any information regarding an itemized trade-in, use the Trade-In sub screen to enter the details in the system. (This sub screen might already contain information supplied during the application entry process.)
To complete the Trade-In sub screen
Field: |
Do this: |
Trade-In |
Asset Type |
Select the asset type. |
Asset Sub Type |
Select the asset sub-type. |
Year |
Specify the year of the asset. |
Make |
Specify the make of the asset. |
Model |
Specify the model of the asset. |
Body |
Specify the body of the asset. |
Identification # |
Specify the identification number. |
Description |
View the asset description. |
Valuation |
Wholesale Amt |
Specify the wholesale value. |
Base Retail Amt |
Specify the retail value. |
Addons Amt (+) |
Specify the add ons value. |
Pay Off Amt (-) |
Specify the payoff amount. |
Total Amt = |
View the total value. |
Valuation Dt |
Specify the valuation date. |
Source |
Select the valuation source. |
Valuation Supplement |
Specify the valuation supplement. |
Edition |
Specify the valuation edition. |
With the Subvention sub tab, available only for Lease, you can review the subvention information from the application entry and calculate the subvention amount, as well as override the calculated subvention amount. The participant’s information is automatically populated based on the selected subvention plan.
To complete the Subvention sub screen
Field: |
Do this: |
Subvention Plan section: |
Plan |
Select the subvention plan. |
Description |
View the subvention plan description. |
Sub Plan |
Select the sub plan. |
Sub Plan Description |
View the subvention sub plan description. |
Subvention Type |
View the subvention type. |
Include |
Check this box to include this record in calculations on the Other Details sub section |
If the application was initially approved automatically, the system displays its recommendations on the Decision tab’s Approved section.
If the application was initially rejected automatically, the system displays its reasons on the Decision link’s Stipulation sub tab.
If you choose to approve or reject the Lease manually, you must manually select the pricing (rule) set by the portfolio company for a specific product. The system validates this pricing against the information in the System Recommendation sections. The information in the Requested section comes from the application entry process and can be edited.
On clicking Calculate, you can calculate the Lease amount, rate, term, and payment. You can use the calculator available in Tools section for completing this step. For detailed information on using the Calculator tools, refer “Tools” chapter in the document.
To verify the application decision data
Field: |
Do this: |
Pricing section |
Current |
Check this box to indicate that this is the current decision. |
Pricing |
View the pricing. |
Decision Dt |
View the decision date. |
Underwriter |
View the underwriter id. |
Status |
View the application status. |
Sub Status |
View the application sub-status. |
Approved section |
ApprovedTerm |
Specify the approved decision term. |
Pmt Amt |
Specify the approved payment amount. Note: If the system parameter ‘Auto Calculate PMT’ is set to ‘Y’ in Setup > Administration > System > System Parameter screen, the system auto calculates the payment amount whenever there is a change in Decision Term or Decision Rate or Max Financed Amount fields. |
Note: Once the payment amount is approved, it will be copied on to the What if Payment field in the Summary sub screen of the Applicants Details screen. |
Pricing Buy Rate |
View the pricing buy rate. |
Approved Buy Rate |
View the approved buy rate which is by default the Pricing Buy Rate displayed above. You can also specify the required approved buy rate. |
Buy Rent Factor |
View the buy rent factor. |
Rate |
Specify the rate. Note: For Islamic products this field is displayed as ‘Profit Rate’. |
Capitalized Cost |
Specify the capitalized cost. |
Grade |
Select the credit grade. |
Score |
Specify the credit score. |
Rent Factor |
Specify the rent factor. |
Residual % |
Specify the residual percentage. |
Bureau 1 |
Specify the Bureau 1. |
Bureau 2 |
Specify the Bureau 2. |
Bureau 3 |
Specify the Bureau 3. |
Comments |
The system determines the best pricing match of all enabled Lease pricing strings in the Setup menu and displays the results in the Pricing and Approved sections.
A 'Re-Score' button is available next to 'Calculate'. Whenever any sensitive Financial or Collateral information is amended in the Application, OFSLL displays a warning message 'Scoring sensitive information is changed. Re-score the application'. You need to click on Re-Score to re-validate the grade and pricing accordingly.
The display of the warning message to Re-score the application can be controlled using the respective System parameter. If the defined System Parameter is flagged 'Y', only then the message is displayed.
If you are underwriting a Lease, record the following information on the Decision tab:
The System Recommendation sub screen displays the system generated Score, Decision and Grade. You will also be able to view the request details of the application under 'Requested' section itself.
A brief description of the fields in System Recommendation section are given below:
Field: |
Do this: |
Score |
View the system recommended score. |
Decision |
View the system recommended decision. |
Grade |
View the system recommended grade. |
A brief description of the fields in Requested section are given below:
Field |
Do this |
View the requested advance amount |
Pmt Amt |
View the requested payment amount. |
Term |
View the requested term (number of payments). |
Requested Rate |
View the requested rate of interest. |
Down Pmt% |
View the down payment percentage |
Down Pmt |
View the down payment amount |
Approx Prc |
View the approximate cash price |
Promotion |
View the promotion type from the drop-down list. |
Balloon Amt |
View the balloon amount. |
Signing Dt |
View the signing date |
View the probable delivery date. |
The Stipulations sub screen allows to add any stipulations or reasons for adverse action you want to attach to the application. Stipulations are items that need to be addressed before the Lease can be funded.
If the application was automatically rejected during the application entry edits, the system displays the automatically generated adverse action codes in this sub screen. If the application is manually rejected by the Underwriter due to adverse action reasons received from bureau or otherwise, the same can be recorded for each of the applicant.
In addition, you can enter comments against specific stipulations as required. Whenever a Stipulation is marked as 'Not Applicable' it becomes mandatory to specify the reason in comments field. Else, system prompts for the reason while processing the application.
To add or view stipulations or reasons for adverse action
A brief description of the fields is given below.
Field: |
Do this: |
Type |
Select the reason type. Type can be Stipulation Reasons or Adverse Action Reasons and Adverse Action Reasons can also be those received from Bureau. |
Name |
The system displays all applicant’s name in the drop down list. You can select the name of the applicant for whom adverse action reason needs to be recorded. In case the stipulation reason is at the application level, then select ALL. |
Code |
Select the reason. |
Description |
Specify the required description. |
Stips Satisfied |
Use the Yes/No/NA buttons to indicate if you verified the stipulation(s) in the Type field |
Comment |
Specify the comment. |
Verified By |
The system updates the user ID of the person who verified the details |
Verified Dt |
The system updates the date when the details are verified. |
If your system is set up to manually load predefined stipulations, click the Load Stipulations button (For more information, refer the following section, Loading Stipulations.)
The system enables you to add multiple records to stipulations using the 'Add Multiple' option.
To add multiple stipulations
The system enables you to automatically transfer stipulations from previous decisions on the Stipulations sub screen with the Copy Stipulations button. This is particularly useful when you are rehashing an application and want to use the same stipulations as those in place for the previous decision.
The system supports the automatic generation of default stipulations on the Underwriting screen’s Stipulations sub screen. The default stipulations can be maintained by company, branch, product, state, application status and application sub-status. When the application status changes (either manually and automatically), the system populates the maintained stipulations with a Stips Satisfied indicator of ‘No’. You can review and update the stipulations accordingly.
You have the option to manually load predefined stipulations by clicking the Load Stipulations button on the Stipulation screen.
To load predefined stipulations
The Itemizations sub screen enables you to add or verify any itemized amounts associated with the application. The list of itemizations is determined by the product you selected in the master screen during the application entry process. The Itemizations sub screen displays an itemization record of the amount financed, such as the cash price, cash down payment, trade-in, unpaid cash price balance and so on. Information that was entered on the Itemization sub screen during the application entry process will appear in the Requested Amt column. Information that you enter as an underwriter in the Approved Amt column will appear in the Itemizations sub screen on the Underwriting screen.
Field: |
Do this: |
Itemization |
Requested Amt |
Approved Amt |
Specify the approved amount. |
Discount Rate |
Specify the discount rate. |
Comment |
Field: |
Do this: |
Trade-in section |
Asset Type |
Asset Sub Type |
Year |
Make |
Model |
Identification # |
Body |
Description |
Valuation section |
Wholesale Amt |
Base Retail Amt |
Addons Amt (+) |
Payoff Amt (-) |
Total Amt = |
Valuation Dt |
Source |
Edition |
The Rate Schedule sub screen is only available for variable rate Lease and displays the rate adjustment frequency information based on product setup.
To view the Rate Schedule sub screen
Field: |
View this: |
Seq |
The rate adjustment sequence number. |
Adjustment Frequency Type |
The rate adjustment frequency type. |
Period |
The rate adjustment period for the frequency. |
# of Adjustments |
The number of rate adjustments for the frequency. |
To complete the Subvention sub tab
Field: |
Do this: |
Plan |
Description |
Sub Plan |
Subvention Type |
Include |
Subvention Detail section: |
Participant |
View the participant. |
Participant Type |
View the participant type. |
Collection Method |
View the collection method. |
Rate |
View the subvention rate. |
Rent Factor |
View the rent factor |
Calculation Method |
View the subvention calculation method. |
Factor |
View the factor. |
Calculated Amount |
View the calculated subvention amount. |
Subvention Amount |
Specify the subvention amount. |
Include |
View if the subvention is included in the application or not. |
Total Subvention Rate |
View the total subvention rate. |
Total Subvention Amt |
View the total subvention amount. |
The Compensation (Lease) sub tab records and displays the terms of compensation between the finance company and the dealer for Lease transactions.
To complete the Compensation (Lease) sub screen
The system loads the following information on the Compensation sub screen:
Field: |
Do this: |
Compensation section |
Compensation Plan |
View the compensation plan. |
View the compensation calculation method. |
Disbursement Method |
View the compensation payment method. |
Spread Formula |
View the compensation spread formula. |
Buy Rate |
Specify the buy rate. |
Buy Rent Factor |
Factor |
View the compensation factor. |
Addl Factor |
View the additional compensation factor. |
Max Spread |
View the maximum spread or percent allowed. |
Max Markup |
View the maximum markup. |
Flat Amt |
View the flat amount. |
Comp Amt |
View the compensation amount. |
The system displays the details and amounts for this compensation plan.
When you click Select Pricing on the Decision tab’s Pricing section, multiple offers appear on the new Multiple Offers sub page. Use the Multiple Offer sub page to select the offer you want to use.
Note
The Multiple Offers sub tab will be enabled only if the Multioffer company parameter is set to Yes.
To view multiple pricing offers
Field: |
Do this: |
Pricing |
View the pricing. |
Term |
Specify the approved term. |
Rate |
Specify the approved rate. |
Pmt Amt |
Specify the approved payment amount. |
Index |
View the approved index. |
Index Rate |
View the approved index rate. |
Margin Rate |
Specify the approved margin. |
Maturity Index |
Specify the approved maturity index. |
Maturity Rate |
Specify the approved maturity rate. |
Accepted |
If selected, indicates that the pricing is accepted. Only one of the current pricings can be accepted. |
Current |
If selected, indicates that the pricing is current. Note: All the available pricings are selected as current. |
The Bureau tab displays the credit report (if pulled) for an applicant. If there is a need for another pull for any applicant, it can be done here manually using the New Request section.
If there are any adverse comments received from the Bureau, system displays them under 'Exceptions/ Comments' section against the specific Bureau record to alert the User. Following are some of the reasons:
The reasons will also be displayed in the Summary tab in 'Bureau' details under 'Exceptions /Comments' section.
To verify the credit bureau data using the Bureau tab
Field: |
View: |
Type |
The credit bureau request type. |
Bureau |
The credit bureau. |
The credit bureau request number. |
Status |
The status of credit bureau request. |
Dt |
The credit bureau request date. |
Report |
The credit bureau report type. |
Credit Bureau Reorder# |
The credit bureau reorder number. |
App Ind |
If selected, indicates that a bureau was pulled for an application. |
Field: |
Do this: |
Type |
View the relation type. |
First Name |
Specify the first name. |
MI |
Specify the middle name. |
Last Name |
Specify the last name. |
Status |
View the credit bureau request status. |
Birth Dt |
Specify the date of birth. |
SSN |
Specify the social security number. Note: If the organizational parameter UIX_HIDE_RESTRICTED_DATA is set to Y, this appears as a masked number; for example, XXX-XX-1234. |
Suffix |
Select the generation. |
Include Debt |
Select to include credit bureau information in the Liabilities section of the Summary sub screen. |
Populate Debt |
Select to load debt information from the credit bureau in the Liabilities section of the Summary sub screen. |
Address Type |
Country |
Address # |
City |
Specify the city. |
State |
Select the state code. |
Street Pre |
Select the street pre type. |
Street Name |
Specify the street name. |
Street Type |
Street Post |
Select the street post type. |
Apt # |
Address Line 2 |
Specify the address line 2. |
Zip |
Zip Extn |
Phone |
Field: |
View: |
Bureau |
The bureau. |
First Name |
The first name. |
MI |
The middle initial. |
Last Name |
The last name. |
SSN |
The social security number. Note: If the organizational parameter UIX_HIDE_RESTRICTED_DATA is set to Y, this appears as a masked number; for example, XXX-XX-1234. |
Birth Dt |
The birth date. |
Note: The SSN and Birth Dt fields in Report Header section are displayed in red if there is a mismatch in the respective data present in the above Applicant/Customer Details section. |
Report Dt |
The report date. |
Onfile Dt |
The on file date. |
Credit Report Id |
The credit report id. |
Best Match |
The best match. |
The system parcels out the details from the credit bureau report in the Bureau screen’s sub tabs (Summary 1, Summary 2, Tradelines, Public Records, Collections, Fraud Messages, Inquiries, Also Known As, Consumer Statements, and Credit Scores).
Field: |
View: |
Trades |
Records of extended installment payments, mortgage and revolving credit, as detailed in the credit bureau report. |
Bankruptcy |
The total number of times the applicant has applied for Chapter 7, Chapter 11 and Chapter 13 bankruptcies, recently and throughout life. |
Past Due |
The total number of times the applicant has been past due on payments by 30, 60, or 90 days in the last year, two years, and throughout life. |
Public Records |
Number of legal actions, including liens, public records, and judgments over the course of the applicant’s life, as well as any that are currently open. |
Collection |
Trades referred to an outside vendor for collection. |
Credit Scores |
View the FICO and bankruptcy scores. |
Statistical Trade Ages |
Ages of the oldest and newest trades, as well as the average age of the open and total trades. |
Derogatory Trades |
Tradelines that an action other than being late was reported; this includes collections, repossessions, charge offs, and bankruptcies. |
In this section: |
View: |
Trades |
Records of extended credit for auto, bank, credit card, retail, Lease finance, and sales finance Lease, as detailed in the credit bureau report. |
Inquiries |
Requests for a credit report regarding Lease in the Trades section over the last six months, as well as total requests over 6, 12, and 24-month periods, as well as the newest and oldest request. |
Balance |
The total balance of retail and bank trades, as well as the high balance of each. |
Open Derogatory |
The following information for all of the customer’s open trade lines: the shortest and longest period of time (in months) since the customer’s most recent minor derogatory (30-60 days late), major derogatory (90-180 days late), and derogatory (bankruptcy, repossession, or charge off). |
Derogatory |
The following information for all of the customer’s total trade lines (open and closed): the shortest and longest period of time (in months) since the customer’s most recent minor derogatory (30-60 days late), major derogatory (90-180 days late), and derogatory (bankruptcy, repossession, or charge off). |
Field: |
View: |
Creditors Name |
The creditors name. |
Status |
The status of the tradeline. |
Type |
The type of tradeline, such as bank, first mortgage, travel card, and so on. |
Type Code |
The code for the type of tradeline. |
Past Due Amt |
The past due amount |
Balance |
The balance of the tradeline. |
Balance Dt |
The balance date. |
Open Dt |
The date the tradeline was opened. |
History Dt |
The trade line’s history date. |
History Data |
The trade line’s history data. |
30 |
The number of times the tradeline was 30 days past due. |
60 |
The number of times the tradeline was 60 days past due. |
90 |
The number of times the tradeline was 90 days past due. |
Creditors Subscriber # |
The creditor’s subscriber number. |
Mop |
The method of payment. |
Account # |
Credit Limit |
The credit limit. |
Term Pmt Amt |
The term payment amount. |
High Balance |
The high balance of the tradeline. |
Reported Dt |
The reported date. |
Duplicate |
If selected, the tradeline is a duplicate. |
Special Exclusion |
If selected, the tradeline is a special exclusion. |
Field: |
View: |
Record Type |
The record type. |
Status |
The status. |
Amount |
The amount. |
Filed Dt |
The filed date. |
Satisfied Dt |
The satisfied date. |
Field: |
View: |
Inquirer Name |
The inquirer’s name. |
Inquirer Subscriber # |
The inquirer’s subscriber number. |
Inquirer Industry Code |
The inquirer’s industry code. |
Inquiry Dt |
The inquiry date. |
Rate Shopping |
If selected, the inquiry concerned rate shopping. |
Duplicate |
If selected, if the inquiry was a duplicate. |
To print the credit bureau data as a text or PDF report
Note
Google Chrome does not support search functionality in the PDF format of the report. Hence you have to enable the ad-hoc plug-in in chrome to use the search facility.
The Credit Bureau Summary screen enables you to manually request a credit pull. Information from a manual credit pull can be used to validate an application.
To manually request a credit bureau report
Field: |
Do this: |
Applicant |
Select the applicant. |
Spouse |
Select the applicant’s spouse (if applicable). |
Bureau |
Select the credit bureau. |
Report |
Select the credit bureau report type. |
The system displays this information in the Bureau Details section.
Note
If you are requesting a report from Experian Credit Bureau for Premier Attribute Consumer report, you can do so without impacting the consumer FICO score. To facilitate the same, the ‘Soft Pull’ check box is to be selected in Bureau Details section. This option is available only when the system parameter ‘EXP_PA_SOFT_PULL_IND’ is enabled in the System Parameters screen and Bureau is selected as ‘EXP’ with Report as ‘PREMIER ATTRIBUTE’ in the Bureau Details section.
The system displays the latest status of the currently requested bureau report in the Bureau Details section. When the report pull process is complete, the Status field in the Bureau Details section changes from pending to Completed.
Having selected and loaded an application, you can view the information about the collateral of the Lease.
The Collateral link opens screens with information regarding any collateral associated with an a. Depending on the type of Lease, collateral can be a vehicle, home or something such as major household appliances. The Collateral tab is unavailable if this is an unsecured Lease.
To verify information about the collateral
Depending on the type of collateral, information about the vehicle, home, or other type of collateral appears.
If you are entering an unsecured Lease, the Collateral link is present but inactive; in which case, skip this step.
To enter collateral information
A brief description of the fields is given below:
Field: |
Do this: |
Existing Asset |
Check this box to indicate that the vehicle is an existing asset. |
Existing Asset ID |
View the existing asset identification number. |
Primary |
Check this box if this is the main asset on the application. |
Asset Class |
Select the asset class. |
Asset Type |
Sub Type |
Select the asset sub type. |
Status |
Select the asset status. |
Type and Description |
Select Make and Model |
Select the make and model of the vehicle from drop-down list. |
Year |
Specify the year of the vehicle. |
Age |
View the age of the vehicle |
Make |
Specify the make of the vehicle. |
Model |
Specify the model of the vehicle. |
Body |
Specify the body of the vehicle. |
Registration # |
Specify the vehicle registration number. |
Identification # |
Specify the vehicle identification number. |
Description |
View the vehicle description. |
Condition |
Select the vehicle condition. |
Address |
Country |
Address # |
Address Line 1 |
Address Line 2 |
Zip |
Zip Extn |
City |
Specify the city. |
State |
Select the state. |
County |
Select the county. |
Usage Details |
Start |
Specify the start. |
Base |
Specify the base. |
Extra |
Specify the extra usage. |
Total |
View the total usage. |
Charge Amt |
Specify the charge amount. |
Using the Vintek interface, the system retrieves the year, make, model and body of the vehicle when you choose Vehicle Details. This time saving feature reduces data entry errors. Using the VIN entered in the Identification Number field, the system populates following fields in the Type & Description section:
If the Vintek interface is unable to retrieve information based on the VIN entered in the Identification Number field, the system displays an error message.
If the collateral is a home, the Collateral link displays information about the home.
Field: |
Do this: |
Existing Asset |
Indicates that the vehicle is an existing asset. |
Existing Asset ID |
Primary |
Select if this is the main asset on the application. |
Asset Class |
Asset Type |
Sub Type |
Occupancy |
Select owner occupancy type. |
Identification # |
Address section |
Country |
Address # |
Specify the home number. |
Address Line 1 |
Address Line 2 |
State |
Specify the state. |
County |
Zip |
Zip Extn |
City |
Specify the city. |
Census Tract/BNA Code |
Specify census tract/BNA (block numbering area) code. |
MSA Code |
Specify the metropolitan statistical area (MSA) code. |
GEO Code |
Specify the geographical code for the property. |
Condition |
Select the condition of the home. |
Description |
Specify a description of the home. |
Select the make and model from the drop-down list |
Year |
Specify the year when the property was built. |
Age |
View the age of the home. |
Make |
Specify the make of the home. |
Model |
Specify the model of the home. |
Width |
Specify the asset width. |
Length |
Specify the asset length. |
Area |
Specify the area of the collateral |
PO# |
Specify the asset purchase order number. |
Legal Description |
Specify the legal description. |
Lot |
Specify the asset lot. |
Sub Division |
Specify the asset sub division. |
Parcel ID |
Specify the parcel id of the home. |
Metes-Bounds |
Check this box to indicate the home is considered Metes-Bounds. |
Flood Zone |
Check this box to indicate the home is in a flood zone. |
1098 Not Required |
Check this box to indicate that the home does not require 1098 |
Deed Details |
Construction permit Dt |
Specify the date on when the construction is permitted. |
Deed Dt |
Specify the date on when the deed is issued |
Deed Place Of Issue |
Specify the place where the deed is issued. |
Properties Boundary from East |
Specify the boundary of the property from the east side. |
North |
Specify the boundary of the property from the north side. |
West |
Specify the boundary of the property from the west side. |
South |
Specify the boundary of the property from the south side. |
If the collateral is any other, the Collateral link displays information about that collateral.
Field: |
Do this: |
Existing Asset |
Existing Asset ID |
Primary |
Asset Class |
Asset Type |
Sub Type |
Status |
Year |
Age |
Make |
Model |
Body |
Registration # |
Identification # |
Description |
Condition |
Address |
Country |
Address # |
Address Line 1 |
Address Line 2 |
State |
Select the state. |
Zip |
Zip Extn |
City |
Specify the city. |
County |
Usage Details |
Start |
Base |
Specify the base. |
Extra |
Total |
Charge Amt |
Specify the charge. |
The Valuation sub tab contains information about the value of the asset. The Values section enables you specify the value of the asset. The Addons section records information about any add ons associated with the collateral.
To complete the Valuations sub tab
Field: |
Do this: |
Value section |
Current |
Select if this is the current valuation. |
Valuation Dt |
Source |
Currency |
Select the currency based on which the valuation is to be done. |
Edition |
Supplement |
Whole Sale |
Lease Currency Wholesale Base Amt |
Specify the Lease currency wholesale value. |
WholesaleBase Amt |
Usage |
Specify the usage value; that is, the monetary effect that the current mileage has on the value of the vehicle. |
Retail |
Retail Base Amt |
Addons Amt (+) |
View the add-ons value. |
Usage Value Amt (+) |
Specify the usage. This pertains to Lease and usually is entered as the current mileage on the vehicle. |
Total Value Amt (=) |
Lease Currency Retail Base Amt |
View the Lease currency retail value. |
Lease Currency Addons Amt(+) |
View the Lease addons. |
Lease Currency Usage Value Amt (+) |
View the Lease currency usage value. |
Lease Currency Total Value Amt (=) |
View the Lease total value. |
Field: |
Do this: |
Description |
Select the description for the attribute. |
Value |
Specify the value of the attribute. |
Amount |
Specify the add-on amount. |
Specify Lease currency amount. |
Complete the Addons/Attributes, Value, and Amt fields for each of the asset’s add-ons and attributes on the application.
The Tracking sub screen enables you to record further information associated with the collateral. What items you choose to track are setup during implementation.
To track attributes for the collateral
Field: |
Do this: |
Tracking Item |
View the tracking type |
Disposition |
Select the disposition. |
Start Dt |
Specify the tracking start date. |
End Dt |
Specify the tracking end date. |
Follow up Dt |
Specify the next follow-up date. |
Enabled |
Select to track the information from the start date in the Start Dt field. |
Comment |
Specify any comments regarding the tracking item. |
The Collateral link’s Seller Details tab enables you to enter the seller details of the collateral of the Lease.
To enter the Seller details
Field: |
Do this |
Seller Information section |
Seller Type |
Select the seller type. |
Seller Name |
Specify the seller name |
Nationality |
Select the seller’s nationality. |
National ID/Reg # |
Specify the national identification number or registration number. |
Authorized Signatory |
Specify the authorized signatory of the seller. |
Seller Address section |
Mailing |
Select if this is the mailing address. Only one address entry can be marked as the mailing address. |
Current |
Select if this is a current address. The mailing address must be marked as current. |
Country |
Select the country code. |
Address # |
Specify the address number. |
Address Line 1 |
Address Line 2 |
State |
Select the state. |
Zip |
Zip Extn |
Select the zip extension. |
City |
Specify the city. |
Phone |
Specify the telephone number. |
Extn |
Select the telephone extension. |
When using the Underwriting screen, you can add/delete comments to an application at any time in the underwriting process by using the Comments screen.
Whenever an application is decisioned by a proxy user, a system generated comment with timestamp is inserted in the comments tab in the format ‘<User 1> actioned as proxy for Underwriter <User2>’. Here, User 1 refers to the logged in user who has acted on behalf of User2, who is the concerned Underwriter. The concerned Underwriter’s name will also be selected in Application section > 'Proxy for Underwriter' field.
To add comments
Field: |
Do this: |
Alert |
Check this box to make the comment appear on the Customer Service screen Alert section |
Type |
Select the type of comment you are adding. |
Sub Type |
Select the sub type of comment you are adding. |
Comment |
Specify your comment. |
Comment By |
The system displays your user ID. |
Comment Dt |
The system displays commented date and time stamp. |
You can delete ‘REGULAR’ type comments displayed in the Comments sub tab.
To delete a comment
When using the Underwriting screen, you can add tracking attribute information to an application at any time in the underwriting process by using the Tracking Attributes screen.
To enter the tracking attributes
Field |
Do this |
Sub-Parameter |
Parameter |
Value |
The Field Investigation link enables lending institutions to perform field investigations and verify an applicant’s contact points (address and employment information, for example) and credentials (such as asset details). Clients can chose the details to be verified (address, employment, asset or any combination of the three), as well as the verifying agency.
With the Underwriting screen’s Field Investigation screen, you can select which details from application entry are to be verified. The verifying agency performs a field investigation of the details and responds to the lending institution with either XML or a text file. The details are entered in the system for an underwriter to review when making a decision.
Field |
Do this |
Applicant |
Select the applicant from the adjoining drop-down list |
Verification Type |
Select the verification type from the adjoining drop-down list. |
Verification Agency |
Select the verification agency from the adjoining drop-down list. |
Status |
Select the status from the adjoining drop-down list. |
Spoke to |
Specify the name of the person applicant spoke to |
Call Dt |
Specify the call date |
# of Attempts |
Specify the number of attempts made. |
Result |
Select the result from the adjoining drop-down list |
Field |
Do this |
Verification Match |
Check the box if the verification has matched. |
Remarks |
Specify remarks, if any |
The Document tab allows you to view documents attached to the application in the form of GIF files, PDF files, DOC files, XLS files and TXT files and add comments regarding a selected.
For more information, see the chapter Document Management in this User Guide.
To view a document attached
Field: |
Do this: |
Document Type |
View the document type. |
Comment |
Specify any comments regarding the document. |
Field: |
View this: |
Document Sub Type |
The document sub type. |
Version |
The version. (Version numbers will be incremental by batch job, first version will start with 1.0.) |
Page # |
The page number. |
Document File Type |
The document file type. |
Tracking # |
The tracking number of the document. |
Docket # |
The docket number of the document. |
Location |
The location of the of the document. |
Received Dt |
The effective date of the document. |
Effective Dt |
Expiry Dt |
The expiration date of the document. |
Comment |
Any comments regarding the document. |
The system opens a browser to display the actual document (which browser appears depends on what type of document you selected and what browsers are set up to work in conjunction with your system).
The Checklist sub tab enables you to view tasks performed during the underwriting process.
To view the underwriting Checklist screen
Field: |
Do this: |
Action |
View the action to be performed. |
Document Type |
Document Sub Type |
View the document sub type. |
Status |
Select the status of the action. |
Response |
Use the Yes/No/NA buttons to indicate whether or not you completed the task. |
Comment |
Specify comment. |
The system can be configured to automatically validate portions of an application when you attempt to change its status. The results of this data check appear on the Verification link’s Edit screen as an Error, a Warning, or an Override.
If it is an Error, the system will not allow you change the application’s status and approve the Lease until you fix all the errors.
If it is a Warning, the system enables you to change an application’s status without correcting the matter. While you should still investigate the problem, Warning messages are of a lesser importance than Error messages.
If it is an Override, the system displays a dialog box informing you that an override is needed; your responsibility level does not have the authority required to process this step. (Choose Yes on the dialog box to move the application to the queue of the user with the required authority.)
The system can be configured to verify different sets of information; for example, the system could check one set of data when checking application entries for completeness and another when approving auto Lease. Each one of these ‘edit types’ has its own set of ‘edit details’.
Note
The Edit Details section’s errors and warnings are created during the setup process.
To complete the Edits section
The system checks the data for the verification process selected in the Edit Type section and displays the results in the Edit Details section.
The Edit Details section contains the following display only information:
Field: |
View this: |
Edit Name |
The edit. |
Result |
The result. |
Expected Value |
The expected value. |
Actual Value |
The actual value. |
Override Responsibility |
The override responsibility, if an override is required. |
The system begins processing the credit application.
The Audits screen is a display only screen that enables you track changes to the contents of predetermined fields (which fields are determined during set up). For example, the Audits screen can be configured to monitor when the contents of the Status and Sub Status is changed. The Audits screen lists the field that was changed, who made the change, when the change was made, and the old and new values in the field.
To view the Audits
Field: |
View: |
Record Id |
The record identifier for the record changed. |
Field |
The field which was changed. |
Old Value |
The old value of the column which was changed. |
New Value |
The new value of the column which was changed. |
Changed By |
The user code who made the change. |
Changed Date |
The date and time when the change was made. |
You can track the time it took a user to complete each stage of the application process with the History section. It displays:
Field: |
View this: |
Status |
The application status. |
Sub Status |
The application sub status. |
User |
The user name. |
Start Dt |
The date and time when the application moved to that status. |
End Dt |
The date and time when the application moved from that status. |
Elapsed Time |
The elapsed time between the status change. |
Ad-hoc correspondence enables you to include information from applications in document templates you create yourself without manually transferring the data. Ad-hoc documents can be generated as either Microsoft Word or PDF files.
Ad-hoc correspondence can be viewed on the Correspondence link’s Correspondence screen when you have opened an account. The screen enables you to generate a new letter or view a previously generated letter.
To generate an ad hoc correspondence
Field: |
Do this: |
Correspondence |
Select the correspondence you want to generated. |
ID |
System displays the correspondence ID. |
Date |
System displays the correspondence generation date. |
The Documents section displays all the types of documents available for the type of correspondence you selected.
Field: |
View this: |
Document ID |
The document ID. |
Document |
The document description. |
Recipient |
The recipient description. |
E-Form Source |
The e-form source. |
Source Type |
The source type. |
Selected |
If selected, indicates that this document is selected to be included in the correspondence. |
Generated |
If selected, indicates that the system generated the document. |
Field: |
Do this: |
Element Type |
View the element type. |
Element |
View the element description. |
Content |
Specify/view the value of the element. |
- or -
The system ‘locks’ the information included in the correspondence and prevents it from being changed.
The system displays a PDF of the ad hoc correspondence.
The recipient details sub tab facilitates you to send ad-hoc correspondence to Applicants, Customers, Producers, and Others as either Fax or Email.
Field: |
Do this: |
Recipient |
Select the recipient from the drop-down list. The list displays the following options: - Applicant - Customer - Producer - Others Note: Based on the type of recipient selected the other correspondence options are displayed for selection. |
Mode |
Select the mode of correspondence from the drop-down list. The list displays the following options: - Fax Note: When the recipient is selected as ‘Applicant’, the Mode is defaulted to Email. |
Type |
Based on the recipient selected, the following type of correspondence is listed for selection: - When the recipient is selected as Applicant, you can select the ‘Applicant Type’ from the drop-down list and ‘Type’ as either EMAIL/ADHOC. The ‘Mode’ is defaulted as ‘Email’. - When the recipient is selected as Customer / Producer, you can select the ‘Mode’ as either FAX/EMAIL and ‘Type’ as FAX/ADHOC or EMAIL/ADHOC respectively. - When the recipient is selected as Others, you can select the ‘Mode’ as either FAX/EMAIL and ‘Type’ as ADHOC only. |
FAX/Email |
Specify the FAX/Email details for correspondence. |
Comments |
Specify additional information as comments. |
System validates the correspondence details and generates a PDF document through BI Publisher with the Correspondence details. The same is emailed to the specified recipient as an attachment and a system generated comment is updated in ‘Comments’ Tab. The correspondence consists of following header details::
Alert |
Type & Subtype |
Comment |
Comment By |
Comment Date |
N |
System Generated |
<Type> <Correspondence type> sent to <Recipient Type> through < Mode> to <'Email' id> |
Logged in user |
Current System date with time stamp |
The Letters link enables you to generate letters using predefined letter templates for Lease.
Letters can be sent in hard copy or Email / Fax. Among the two options provided for each of these options, you can select the required mode for sending letters.
In addition to the above, a section for recording 'Recipient details' opens below. On clicking 'Add' you can specify recipient details, Mode, Type, provide comments and Save the same.
Comments captured will be appended to Fax / Email sent to recipient. You will then need to click on the 'Send' in the action block for email / fax to be sent from OFSLL. In case the correspondence generation is dependent on any job run, then on click of 'Send' system displays an error message "Fax / Letter not generated. Please try sending later”; else event successful message is displayed.
On the Underwriting screen, these predefined correspondences are as follows:
To generate letters on the Underwriting screen
UNDERWRITING:
The predefined Decision letter is automatically sent after an application receives a status of approved, rejected, or conditioned on the Underwriting screen.
The Decision fax/e-mail is available for Lease (fixed and variable rate).
The predefined Lease Adverse Action letter is automatically sent to the producer after a configurable number of days when an application receives a status of rejected on the Underwriting screen.
The Adverse Action letter is available for Lease (fixed and variable rate).
The predefined Conditional Adverse Action letter is automatically sent to the producer a configurable number of days after an application receives a status of conditioned on the Underwriting screen.
The Conditional Adverse Action letter is available for Lease (fixed and variable rate).
Field: |
Do this: |
Recipient |
Mode |
Type |
FAX/Email |
Comments |
Alert |
Type & Subtype |
Comment |
Comment By |
Comment Date |
N |
System Generated |
Logged in user |
The Tools tab calculates the payment amount, term, interest rate, Lease amount, amortization schedule and allows for the printing of a report.
For detailed information on using the tools, refer “Tools” chapter in the document.
