With the Scenario Analysis screen, you can simulate the customer’s Line of credit request Line of credit amount, rate and create a mock proposal in Line of credit with your lending policies.
You can use scenario analysis screen to complete the following tasks:
Note
Depending on the product licensed, you can view either Loan or Lease Calculator details. If you have licensed both, then you are provided with an option in Scenario Analysis screen to select the required Product Type.
You can view a previously generated scenario analysis by inquiring through the identification code,
To view an existing scenario analysis
To generate a scenario analysis
Click Add and complete the following Parameters:
You can click Initialize to clear (or ‘refresh’) the screen
details at any time.
Field |
Do this: |
Inquiry Id |
View the inquiry identification code. |
Application # |
View the application number. |
First Name |
Specify the first name of the applicant. |
Last Name |
Specify the last name of the applicant. |
Phone |
Specify the phone number of the applicant. |
Specify the email address of the applicant. |
Company |
Select the company. |
Branch |
Select the branch. |
Product |
Select the product. |
Producer Type |
Select the producer type associated with the product. |
Producer Name |
Select the producer associated with the product. |
Producer Contact Number |
View the producer contact number. |
Region |
View the region where the producer belongs. |
Territory |
View the territory where the producer belongs. |
Term |
Specify the requested term (number of payments). |
State |
Select the state code. |
Asset Type |
Select the asset type. |
Asset Sub type |
Select the asset sub type. |
Make |
Specify the make of the vehicle. |
Model |
Specify the model of the vehicle. |
Promotion |
Select the requested promotion. |
Billing Cycle |
Select the billing cycle schedule. |
Instrument |
Select the instrument. |
The system auto assigns an identification code to your calculations on the Scenario Analysis screen.
The Scenario Analysis screen provides an option to calculate and display the Pricing based on previously generated scenario analysis details.
To create an application from the scenario analysis
You can generate a summarised report using the calculated details in the format of quote.
After you have specified all the required information to generate scenario analysis, (Refer section Generating Scenario Analysis), click Print Quote.
For detailed information, refer to Printing a Quote section in Tools chapter.
The system assigns the information on the Scenario Analysis screen an application number. You can open this application on the Application Entry screen and view information from the Scenario Analysis screen at the following locations:
In the Underwriting screen, the Decision link’s Pricing and Approved sections display the details from the Scenario Analysis screen. You can modify the price chosen in the Scenario Analysis screen and re-price the application. If application has been repriced, the comments regarding the multiple offers on the Comment screen should be manually updated before approving the application.
