Some tables are defined in the oudm_sys schema and use a DWC_ prefix, but are not part of Oracle Utilities Data Model.
You use the DWC_ control tables when processing the model. For example when loading data or when monitoring errors.
This appendix includes the following sections:
Use the oudm_execute_wf.sh program to manually execute the Intra-ETL. Before you run the Intra-ETL, for an incremental load, you must update the Oracle Utilities Data Model Relational ETL parameters in DWC_ETL_PARAMETER table so that this information can be used when loading the relational data. This program prompts for several environment parameter values. And reads ETL parameters from DWC_ETL_PARAMETER table, as shown in Table A-1, and DWC_OLAP_ETL_PARAMETER table, as shown in Table A-2.
The PKG_DWD_*_MAP loads data from Oracle Utilities Data Model base tables into the Oracle Utilities Data Model derived tables. These packages read relational ETL parameters from the DWC_ETL_PARAMETER table.
You update the parameters in DWC_ETL_PARAMETER control table in the oudm_sys schema so that this information can be used when loading the derived and aggregate tables and views.
Table A-1 describes the valid values for the DWC_ETL_PARAMETER table.
Table A-1 DWC_ETL_PARAMETER Table
| Column | Description |
Process_name |
OUDM-INTRA-ETL |
from_date_etl |
The start date of ETL period. |
to_date_etl |
The end date of ETL period. |
load_dt |
The date when this record are populated. |
last_updt_dt |
The date when this record are last updated |
last_updt_by |
The user who last updated this record |
The OLAP MAP mapping that loads OLAP cube data invokes the analytic workspace build function from the PKG_OUDM_OLAP_ETL_AW_LOAD package. This package loads data from Oracle Utilities Data Model aggregate materialized views into the Oracle Utilities Data Model analytical workspace and calculates the forecast data. The PKG_OUDM_OLAP_ETL_AW_LOAD reads OLAP ETL parameters from the DWC_OLAP_ETL_PARAMETER table.
You update the Oracle Utilities Data Model OLAP ETL parameters in DWC_OLAP_ETL_PARAMETER control table in the oudm_sys schema so that this information can be used when loading the OLAP cube data.
Table A-2 describes the valid values for the DWC_OLAP_ETL_PARAMETER table. For more information on the values to specify when performing an initial load of OLAP cube data or when refreshing the OLAP cubes after an initial load, see Oracle Utilities Data Model Implementation and Operations Guide.
Table A-2 ETL Parameters in the DWC_OLAP_ETL_PARAMETER Table
| Column Name | Description |
PROCESS_NAME |
OUDM_OLAP_ETL |
BUILD_METHOD |
Cube build/refresh method specified by one of the following values:
CUBENAME |
Specifies the cubes you want to build:
MAXJOBQUEUES |
A decimal value that specifies the number of parallel processes to allocate to this job. (Default value is The number of parallel processes actually allocated by a build is controlled by the smallest of these factors:
CALC_FCST |
Whether or not to calculate forecast cubes:
NO_FCST_YRS |
A decimal value that specifies how many years forecast data you want to calculate. (This parameter takes effect only if you set CALC_FCST to |
FCST_MTHD |
FCST_ST_YR |
A value specified as |
FCST_END_YR |
OTHER1 |
Reserved for future use. (Default value is |
OTHER2 |
The two control table in the oudm_sys schema, DWC_INTRA_ETL_PROCESS and DWC_INTRA_ETL_ACTIVITY, monitor the execution of the Intra-ETL process.
Table A-3 contains column name information for DWC_INTRA_ETL_PROCESS. Table A-4 contains column name information for DWC_INTRA_ETL_ACTIVITY.
Table A-3 DWC_INTRA_ETL_PROCESS Columns
| Columns Name | Data Type | Not Null | Remarks |
PROCESS_KEY |
NUMBER(30) |
Yes |
Primary Key, System Generated Unique Identifier |
PROCESS_START_TIME |
DATE |
Yes |
ETL Process Start Date and Time |
PROCESS_END_TIME |
DATE |
ETL Process End Date and Time |
No value |
PROCESS_STATUS |
VARCHAR2(30) |
Yes |
Current status of the process |
FROM_DATE_ETL |
DATE |
Start Date (ETL) - From Date of the ETL date range |
No value |
TO_DATE_ETL |
DATE |
End Date (ETL) - To Date of the ETL date range |
No value |
LOAD_DT |
DATE |
Record Load Date - Audit Field |
No value |
LAST_UPDT_DT |
NUMBER(30) |
Last Update Date and Time - Audit Field |
No value |
LAST_ UPDT_BY |
VARCHAR(30) |
Last Update By - Audit Field |
No value |
Table A-4 DWC_INTRA_ETL_ACTIVITY Columns
ACTIVITY_KEY |
NUMBER(30) |
Yes |
PROCESS_KEY |
NUMBER(30) |
Yes |
Process Key. FK to DWC_INTRA_ETL_ PROCESS table |
ACTIVITY_NAME |
VARCHAR2(50) |
Yes |
Activity Name or Intra ETL Program Name |
ACTIVITY_DESC |
VARCHAR2(500) |
Activity description |
No value |
ACTIVITY_START_TIME |
DATE |
Yes |
Intra ETL Program Start Date and Time |
ACTIVITY_END_TIME |
DATE |
Intra ETL Program End Date and Time |
No value |
ACTIVITY_STATUS |
VARCHAR2(30) |
Yes |
ERROR_DTL |
VARCHAR2(2000) |
Error details if any |
No value |
LOAD_DT |
DATE |
No value |
LAST_UPDT_DT |
NUMBER(30) |
No value |
LAST_ PDT_BY |
VARCHAR(30) |
No value |
