This chapter of Oracle Utilities Data Model Reference describes the Data Flow between fact tables and dimension tables of Oracle Utilities Data Model relational part to target materialize views and cubes to support the module Oracle Utilities Data Model OLAP.
This chapter includes the following section:
For more information, see Oracle Utilities Data Model OLAP Model Dimensions.
All materialized views underlying the OLAP cubes are disabled by default. To enable the cube materialized views, you must follow the steps outlined in Oracle Utilities Data Model Implementation and Operations Guide.
For each cube, each section includes the following cube information:
Description
Dimensions (leaf load level and load sequence)
Base Measures with Physical Mapping and Description
Derived Measure with the Logical Name and the Calculations
This section lists the Oracle Utilities Data Model OLAP cubes.
Oracle Utilities Data Model includes base measures with format such as, XXXX1. These base measures are intended for internal; Oracle Utilities Data Model uses these base measures to calculate EOP_XXXX (end of period value). Do not use these measures for reporting.
This cube provides information on the aggregate meter readings of different accounts by month. It is based on dimensions like time, meter, and account.
Physical Name: ACCTMTRR
Dimensions and Load Level
The fact data of Meter Reading Account Cube will be loaded from the relational schema at these dimension levels (leaf level).
Table 9-1 Meter Reading Account Cube Dimensions and Load Level
| Dimension Name | Load Level |
 Account  |
 Account  |
 Meter  |
 Meter  |
 Time  |
 Calendar Month  |
Aggregation Order/Operator
The Meter Reading Account Cube is aggregated by the order and operators on dimensions shown in Table 9-2.
Table 9-2 Meter Reading Account Cube Aggregation and Order
| Dimension Name | Operator | Order |
 Time  |
 Sum  |
 1  |
 Account  |
 Sum  |
 2  |
 Meter  |
 Sum  |
 3  |
Table 9-3 Meter Reading Account Cube Descriptions and Physical Columns
| Physical Name | Description | Measure Type | Physical Column |
 MXKW  |
 Max KW  |
 Measure  |
 DWA_MTR_RDNG_MO_ACCT.MAX_KW  |
 TMXKW  |
 Total Max KW  |
 Measure  |
 DWA_MTR_RDNG_MO_ACCT.TOT_KWH  |
 MXKW_LP  |
 Max KW Last Period  |
 Calculated Measure  |
 LAG(ACCTMTRR.MXKW, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 MXKW_LY  |
 Max KW Last Year  |
 LAG(ACCTMTRR.MXKW, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD  |
 Max KW YTD  |
 SUM(ACCTMTRR.MXKW) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 MXKW_YTD_LY  |
 MAX KW YTD Last Year  |
 LAG(ACCTMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD_PCT_LY  |
 MXKW YTD Percent Change Last Year  |
 LAG_VARIANCE_PERCENT(ACCTMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_LP  |
 Total KWH Last Period  |
 LAG(ACCTMTRR.TKWH, 1) OVER HIERARCHY ("TIME".HTCLNDR)  |
 TKWH_LY  |
 Total KWH Last Year  |
 LAG(ACCTMTRR.TKWH, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD  |
 Total KWH YTD  |
 SUM(ACCTMTRR.TKWH) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 TKWH_YTD_LY  |
 Total KWH YTD Last Year  |
 LAG(ACCTMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD_PCT_LY  |
 Total KWH YTD Percent Change Last Year  |
 LAG_VARIANCE_PERCENT(ACCTMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
This cube stores the aggregates on the end device events by customer by month. It is based on time, customer, and operational usage point dimensions.
Physical Name: CUST_ENDVC
The fact data of End Device Event Customer Cube will be loaded from the relational schema at these dimension levels (leaf level).
Table 9-4 End Device Event Customer Cube Dimensions and Load Level
 Time  |
 Business Month  |
 Customer  |
 Customer Code  |
 Operational Usage Point  |
 Sub Station  |
The End Device Event Customer Cube is aggregated by the order and operators on dimensions shown in Table 9-5.
Table 9-5 End Device Event Customer Cube Aggregation and Order
 Time  |
 Sum  |
 1  |
 Customer  |
 Sum  |
 2  |
 Sum  |
 3  |
Table 9-6 End Device Event Customer Cube Description and Physical Columns
 RVS_MTR_CNT  |
 Reversed Meter Count  |
 Measure  |
 DWA_END_DVC_EVT_DVC_MO.RVS_MTR_CNT  |
 STPD_MTR_CNT  |
 Stopped Meter Event Count  |
 Measure  |
 DWA_END_DVC_EVT_DVC_MO.STPD_MTR_CNT  |
 TMPR_MTR_CNT  |
 Tamper Meter Count  |
 Measure  |
 DWA_END_DVC_EVT_DVC_MO.MTR_TMPR_EVT_CNT  |
 RVS_MTR_CNT_LP  |
 RVS MTR CNT Last Period  |
 LAG(CUST_ENDVC.RVS_MTR_CNT, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 RVS_MTR_CNT_LY  |
 RVS MTR CNT Last Year  |
 LAG(CUST_ENDVC.RVS_MTR_CNT, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 STPD_MTR_CNT_LP  |
 Stopped MTR CNT Last Period  |
 LAG(CUST_ENDVC.STPD_MTR_CNT, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 STPD_MTR_CNT_LY  |
 Stopped MTR CNT Last Year  |
 LAG(CUST_ENDVC.STPD_MTR_CNT, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TMPR_MTR_CNT_LP  |
 TMPR MTR CNT Last Period  |
 LAG(CUST_ENDVC.TMPR_MTR_CNT, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 TMPR_MTR_CNT_LY  |
 TMPR MTR CNT Last Year  |
 LAG(CUST_ENDVC.TMPR_MTR_CNT, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
This cube stores the aggregates on the end device events by different devices by month. It is based on time, meter, and manufacturer dimensions.
Physical Name: DVC_ENDVC
The fact data of End device Event by Device Cube will be loaded from the relational schema at these dimension levels (leaf level).
Table 9-7 End Device Event by Device Cube Dimensions and Load Level
 Manufacturer Product  |
 Asset Model  |
 Meter  |
 Meter  |
 Time  |
 Calendar Month  |
The End Device Event by Cube is aggregated by the order and operators on dimensions shown in Table 9-8.
Table 9-8 End Device Event by Device Cube Aggregation and Order
 Manufacturer  |
 Sum  |
 1  |
 Meter  |
 Sum  |
 2  |
 Time  |
 Sum  |
 3  |
Table 9-9 End Device Event by Device Cube Description and Physical Columns
 RVS_MTR_CNT  |
 Measure  |
 STPD_MTR_CNT  |
 Measure  |
 TMPR_MTR_CNT  |
 Measure  |
 RVS_MTR_CNT_LP  |
 LAG(DVC_ENDVC.RVS_MTR_CNT, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 RVS_MTR_CNT_LY  |
 LAG(DVC_ENDVC.RVS_MTR_CNT, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 STPD_MTR_CNT_LP  |
 LAG(DVC_ENDVC.STPD_MTR_CNT, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 STPD_MTR_CNT_LY  |
 LAG(DVC_ENDVC.STPD_MTR_CNT, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TMPR_MTR_CNT_LP  |
 LAG(DVC_ENDVC.TMPR_MTR_CNT, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 TMPR_MTR_CNT_LY  |
 LAG(DVC_ENDVC.TMPR_MTR_CNT, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
This cube provides information on the aggregate meter reading by different geographies by month. It is based on the following dimensions like time, meter, and geography usage point.
Physical Name: GUSPMTRR
The fact data of Meter Reading Geo Usage Point Cube will be loaded from the relational schema at these dimension levels (leaf level).
Table 9-10 Meter Reading Geo Usage Point Cube Dimensions and Load Level
 Geography Usage Point  |
 Meter  |
 Meter  |
 Time  |
 Calendar Month  |
The Meter Reading Geo Usage Point Cube is aggregated by the order and operators on dimensions shown in Table 9-11.
Table 9-11 Meter Reading Geo Usage Point Cube Aggregation and Order
 Time  |
 Sum  |
 1  |
 Meter  |
 Sum  |
 2  |
 Sum  |
 3  |
Table 9-12 Meter Reading Geo Usage Point Cube Description and Physical Columns
 MXKW  |
 Max KW  |
 Measure  |
 DWA_MTR_RDNG_MO_UP.MAX_KW  |
 TMXKW  |
 Total KW Hour  |
 Measure  |
 DWA_MTR_RDNG_MO_UP.TOT_KWH  |
 MXKW_LP  |
 LAG(GUSPMTRR.MXKW, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 MXKW_LY  |
 Max KW Last Year  |
 LAG(GUSPMTRR.MXKW, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD  |
 Max KW YTD  |
 SUM(GUSPMTRR.MXKW) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 MXKW_YTD_LY  |
 LAG(GUSPMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD_PCT_LY  |
 LAG_VARIANCE_PERCENT(GUSPMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_LP  |
 LAG(GUSPMTRR.TKWH, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 TKWH_LY  |
 LAG(GUSPMTRR.TKWH, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD  |
 Total KWH YTD  |
 SUM(GUSPMTRR.TKWH) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 TKWH_YTD_LY  |
 LAG(GUSPMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD_PCT_LY  |
 LAG_VARIANCE_PERCENT(GUSPMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
This cube provides information on the aggregate meter reading by operational usage points by month. It is based on time, meter, and operational usage point dimensions.
Physical Name: OUSPMTRR
The fact data of Meter Reading Operational Usage Point Cube will be loaded from the relational schema at these dimension levels (leaf level).
Table 9-13 Meter Reading Operational Usage Point Cube Dimensions and Load Level
 Usage  |
 Point  |
 Meter  |
 Meter  |
 Time  |
 Calendar Month  |
The Meter Reading Operational Usage Point Cube is aggregated by the order and operators on dimensions shown in Table 9-14.
Table 9-14 Meter Reading Operational Usage Point Cube Aggregation and Order
 Time  |
 Sum  |
 1  |
 Meter  |
 Sum  |
 2  |
 Sum  |
 3  |
Table 9-15 Meter Reading Operational Usage Point Cube Description and Physical Columns
 MXKW  |
 Max KW  |
 Measure  |
 TMXKW  |
 Total KW Hour  |
 Measure  |
 MXKW_LP  |
 LAG(OUSPMTRR.MXKW, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 MXKW_LY  |
 Max KW Last Year  |
 LAG(OUSPMTRR.MXKW, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD  |
 Max KW YTD  |
 SUM(OUSPMTRR.MXKW) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 MXKW_YTD_LY  |
 LAG(OUSPMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD_PCT_LY  |
 LAG_VARIANCE_PERCENT(OUSPMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_LP  |
 LAG(OUSPMTRR.TKWH, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 TKWH_LY  |
 LAG(OUSPMTRR.TKWH, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD  |
 Total KWH YTD  |
 SUM(OUSPMTRR.TKWH) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 TKWH_YTD_LY  |
 LAG(OUSPMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD_PCT_LY  |
 LAG_VARIANCE_PERCENT(OUSPMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
This cube stores the aggregate meter reading by different regions by month. This cube is based on dimensions, time, region, and meter.
Physical Name: RUSPMTRR
The fact data of Meter Reading Regional Usage Point Cube will be loaded from the relational schema at these dimension levels (leaf level).
Table 9-16 Meter Reading Regional Usage Point Cube Dimensions and Load Level
 Regional Usage Point  |
 Meter  |
 Meter  |
 Time  |
 Calendar Month  |
The Meter Reading Regional Usage Point Cube is aggregated by the order and operators on dimensions shown in Table 9-17.
Table 9-17 Meter Reading Regional Usage Point Cube Aggregation and Order
 Time  |
 Sum  |
 1  |
 Meter  |
 Sum  |
 2  |
 Sum  |
 3  |
Table 9-18 Meter Reading Regional Usage Point Cube Description and Physical Columns
 MXKW  |
 Max KW  |
 Measure  |
 TMXKW  |
 Total KW Hour  |
 Measure  |
 MXKW_LP  |
 LAG(RUSPMTRR.MXKW, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 MXKW_LY  |
 Max KW Last Year  |
 LAG(RUSPMTRR.MXKW, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD  |
 Max KW YTD  |
 SUM(RUSPMTRR.MXKW) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 MXKW_YTD_LY  |
 LAG(RUSPMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD_PCT_LY  |
 LAG_VARIANCE_PERCENT(RUSPMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_LP  |
 LAG(RUSPMTRR.TKWH, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 TKWH_LY  |
 LAG(RUSPMTRR.TKWH, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD  |
 Total KWH YTD  |
 SUM(RUSPMTRR.TKWH) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 TKWH_YTD_LY  |
 LAG(RUSPMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD_PCT_LY  |
 LAG_VARIANCE_PERCENT(RUSPMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
Physical Name: CUSTMTRR
The fact data of Meter Reading Customer Cube will be loaded from the relational schema at these dimension levels (leaf level).
Table 9-19 Meter Reading Customer Cube Dimensions and Load Level
 Customer  |
 Customer  |
 Meter  |
 Meter  |
 Time  |
 Calendar Month  |
The Meter Reading Customer Cube is aggregated by the order and operators on dimensions shown in Table 9-20.
Table 9-20 Meter Reading Customer Cube Aggregation and Order
 Time  |
 Sum  |
 1  |
 Customer  |
 Sum  |
 2  |
 Meter  |
 Sum  |
 3  |
Table 9-21 Meter Reading Regional Usage Point Cube Description and Physical Columns
 MXKW  |
 Max KW  |
 Measure  |
 DWA_MTR_RDNG_MO_CUST.TOT_KWH  |
 TMKW  |
 Total kilo watt hour  |
 Measure  |
 DWA_MTR_RDNG_MO_CUST.MAX_KW  |
 MXKW_LP  |
 LAG(CUSTMTRR.MXKW, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 MXKW_LY  |
 Max KW Last Year  |
 LAG(CUSTMTRR.MXKW, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD  |
 Max KW YTD  |
 SUM(CUSTMTRR.MXKW) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 MXKW_YTD_LY  |
 LAG(CUSTMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 MXKW_YTD_PCT_LY  |
 LAG_VARIANCE_PERCENT(CUSTMTRR.MXKW_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_LP  |
 LAG(CUSTMTRR.TKWH, 1) OVER (HIERARCHY "TIME".HTCLNDR)  |
 TKWH_LY  |
 LAG(CUSTMTRR.TKWH, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD  |
 Total KWH YTD  |
 SUM(CUSTMTRR.TKWH) OVER HIERARCHY ("TIME".HTCLNDR BETWEEN UNBOUNDED PRECEDING AND CURRENT MEMBER WITHIN ANCESTOR AT LEVEL "TIME".CLNDR_YR)  |
 TKWH_YTD_LY  |
 LAG(CUSTMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
 TKWH_YTD_PCT_LY  |
 LAG_VARIANCE_PERCENT(CUSTMTRR.TKWH_YTD, 1) OVER HIERARCHY ("TIME".HTCLNDR BY ANCESTOR AT LEVEL "TIME".HTCLNDR.CLNDR_YR POSITION FROM BEGINNING)  |
