mlib_ImageMulAlpha_Fp_Inp - alpha channel multiplication
cc [ flag... ] file... –lmlib [ library... ] #include <mlib.h> mlib_status mlib_ImageMulAlpha_Fp_Inp(mlib_image *srcdst, mlib_s32 cmask);
The mlib_ImageMulAlpha_Fp_Inp() function multiplies floating-point color channels by the alpha channel on a pixel by pixel basis, in place.
It uses the following equation:
srcdst[x][y][c] = srcdst[x][y][c] * srcdst[x][y][a]
where c and a are the indices for the color channels and the alpha channel, respectively, so c != a.
The function takes the following arguments:
Pointer to source and destination image.
Channel mask to indicate the alpha channel. Each bit of the mask represents a channel in the image. The channel corresponding to the 1 bit of cmask is the alpha channel.
The function returns MLIB_SUCCESS if successful. Otherwise it returns MLIB_FAILURE.
mlib_ImageMulAlpha(3MLIB), mlib_ImageMulAlpha_Inp(3MLIB), mlib_ImageMulAlpha_Fp(3MLIB), attributes(5)
