Product Overview
The Dual Port 25Gb Ethernet Adapter is a standalone card that is used for virtualized
cloud deployments and network virtualization. Each adapter port uses a 25GbE SFP28
optical transceiver with an LC/LC cable or a copper DAC that has transceivers attached
at each end. Both ports operate at the same speed. The adapter is a PCIe 3.0 x8
low-profile card.
Data rate supported per port
2 x 25 GbE, where both ports operate at 25 Gbps per port.
Bus type
PCIe V3.0, 8.0 GTps
Bus width
8-lane PCIe bus connector
Conforms to Ethernet standard
802.3
Boot ROM
8 Mb SPI Flash
Electromagnetic interference (EMI)
FCC Class A
