| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2017, Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
This chapter describes how to set up Siebel Mobile connected applications. It includes the following topics:
Roadmap for Setting Up Siebel Mobile Disconnected Applications
Requirements for Setting Up Siebel Mobile Disconnected Applications
Adding Object Managers for Siebel Mobile Disconnected Applications
Siebel Application Object Manager Parameters for Siebel Mobile Disconnected Applications
Process of Configuring Siebel Server for Siebel Mobile Disconnected Applications
Guidelines for Developing Data Filters for Siebel Mobile Disconnected Applications
Copying and Deleting Siebel Mobile Disconnected Applications
Note: The procedures in this guide assume that you do not use the Tree navigation control option to access screens and views. However, you can choose to use the Tree navigation control if required. For more information about setting navigation options, see Siebel Fundamentals Guide. |
