| Siebel CRM Siebel Mobile Guide: Disconnected Siebel Innovation Pack 2017, Rev. A E52427-01 |
![]() Previous |
![]() Next |
View PDF |
The features listed in this topic are not supported in offline mode. You must be connected to the Internet and, in some cases, to the Siebel Server to do the following in your Siebel Mobile disconnected application:
Directly create new records
You cannot directly create new records using New in offline mode. In the case of child views where records are being associated, associating a downloaded record with a selected record using Add is supported in offline mode. For more information, see "Creating Records in Siebel Mobile".
Use the cogwheel icon
For more information, see "About Menu (the Cogwheel Icon) in Siebel Mobile"
Use the following icons to make a selection or type some text: Phone, Email, Pin, URL
Select multiple records in list applets
Note : Multiple record selection for associate applets only is supported in offline mode. |
Other features not supported in offline mode include:
Cascade delete
Currency pop-up controls
Default Applet Menu items
Dynamic drilldowns
Dynamic controls
Execution of joined fields
Inline query in list applets
MVG (multi-value group) fields. MVG fields are read-only in offline mode
Thread bar
Toggle applets
The Back button to go to a previous page
The Show More option in List applets is unavailable
The User Settings view is unavailable.
The expression parser is limited
The expression parser is used for parsing expressions such as those for field validations, predefault and post-default properties, Business Component search specifications, and so on.
The expression parser does not support all the expressions that are supported by Siebel Server.
