| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Click the box beside or after an option to select or clear the check box. When you click an empty box, a check mark or an X appears in the box. If you click a box that is selected, then the check mark or X disappears.
Figure 4-3 shows an example of check boxes.
In query mode, check boxes have a third possible state. For more information about using check boxes in query mode, see "Tips for Queries".
You can press the space bar to select and deselect check boxes.
