| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Some issues to note about the application user interface behavior include the following:
Lock. The lock option is not supported in hierarchical list applets.
Pick lists and LOV's. Pick lists and LOVs do not select a new value until a unique match is made. If you are using auto-fill but an exact match is not made, then the value reverts to the original. Double-quotes are not included when you select from an LOV.
Quotes. Quotes are not included when you select an option from an LOV. Double quotes are required for strings.
