| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
In your Siebel Web client application, people with visual impairment can use screen magnification utilities to enlarge selected text and other on-screen elements for easier viewing. Several operating systems supply magnification utilities. Also, you can purchase these utilities from third-party vendors. Your Siebel Web client application supports magnification utilities that work in browser-based applications.
In your Siebel Web client application, people with visual impairment can use zoom features and high-contrast options for browsers to facilitate viewing.
The Siebel Web client application supports screen readers that work in browser-based applications. Screen readers provide an audible description of the field contents as you navigate through the user interface. It is recommended that you use screen readers that comply with Accessible Rich Internet Applications (ARIA).
The Siebel Web client application supports screen readers that are browser-compatible because it is a standards-based Web application. Some browsers interpret Accessible Rich Internet Applications (ARIA) and Version 2.0 of Web Content Accessibility Guidelines (WCAG) better than other browsers. Use the appropriate browser for your implementation. Consult with the vendor for your screen reader to use it with your Web application.
If you use a screen reader, then you hear the levels of the bar region that denote user interface areas. Table 19-1 shows the level of the bar region that corresponds to each user interface area that sighted users work with.
Table 19-1 Levels of Bar Region for User Interface Areas
| User Interface Area | Level of Bar Region |
One of the following:
First level |
Second level |
Third level |
Fourth level |
