| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
After you use the Siebel Web client application, you exit it.
Note: Do not close the browser window by clicking Close (X) in the upper corner of the page to exit the application. Automatic logout upon closing the browser is not supported. Always log out of the application explicitly by using the Log Out button. |
To log out of the application
Complete either of the following steps:
From the application menu, choose File, then Log Out.
Click Settings on the menu toolbar on the application banner, and then click Log Out.
Clicking Close (X) in the upper corner of a window rather than explicitly using the Log Out button to exit a browser is not supported. It is recommended to set session time out intervals as short as possible while maintaining usability, and to train users to log out of the application by using the Log Out button.
