Go to primary content
Siebel CRM Fundamentals Guide
Siebel Innovation Pack 2017, Rev. A
E52425-01
  Go to Documentation Home
Home
Go To Table Of Contents
Contents
Go To Index
Index
Previous
Previous
Next
Next
    View PDF
Receiving Inbound Work Items
When an inbound work item is routed to you, the Accept Work Item button blinks, and you can accept and begin working on the item.
The Accept Work Item button shows what type of work item is coming in: a Phone icon represents a voice call, an Envelope icon represents an email message, and so on.
When an inbound work item arrives, the following events might also occur:
Accepting an Inbound Work Item
This procedure describes how to accept an inbound work item.
To accept an inbound work item
  • Click Accept Work Item when the button blinks to indicate the arrival of a work item.
    You can have multiple work items at the same time, such as voice calls on hold or other paused work items. However, only one work item is active at a time. The channel type of the active work item appears on the side of the communications toolbar.
Releasing an Inbound Work Item
This procedure describes how to release an inbound work item.
To release the current work item
  1. Select the work item from the Work Items list.
  2. Click Release Work Item, as appropriate for the channel type for the work item.
If you are working with an activity record or another type of record that is automatically associated with a work item, then you must save any changes to the record before you release the work item. In addition, to make changes after releasing the work item, you must first refresh the record. Otherwise, changes you make to the record might be lost.
