| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You can have inbound work items of supported channel types forwarded to you, such as having voice calls forwarded to you at a different extension. Only work items subsequently routed to you are forwarded. The toolbar button is a toggle, where the button name changes depending on the state.
To specify forwarding for inbound work items
In the text input field, enter the contact information, such as a phone extension, where you want your work items forwarded.
Click Forward Work Items.
Toggle the button to cancel forwarding.
