| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
When composing an outgoing message, agents might not have the time or information that they need to complete the message and then send it. They can save this incomplete message, and then later retrieve this draft to complete the message before sending it. For more information, see "Retrieving Drafts of Outgoing Messages".
You can save a draft of sent messages and of outgoing messages. After you save a draft of an outgoing message:
If you select the Remain on Same View After Send (Cancel) field in the Outbound Communications view of the User Preferences screen, then the outgoing message form continues to appear. You must navigate to the Communications List view to see a record of the draft of the outgoing message.
If you do not select the Remain on Same View After Send (Cancel) field in the Outbound Communications view of the User Preferences screen, then the Communications List view appears.
To save a draft of an outgoing message
Navigate to the Communications screen, then the Communications List view.
Select Inbox or Sent Items in the Saved Queries field of the toolbar.
In the list of email messages, select the message that you want to save as a draft.
Navigate to the outgoing message form:
Click Reply to respond to only the individual who sent the message.
Click Reply to All to respond to the individual who sent the message and to the individuals in the Cc: field of the message.
Click Forward to respond to the individuals whom you select in the outgoing message form.
The form for the incoming message appears on-screen. To show or hide the body of the incoming message, click the show more or show less button in the corner of the incoming message form.
The form for your outgoing message appears after the form for the incoming message.
Enter text for the outgoing message in the area of the message body that precedes the Thread ID reference.
At the start or end of the outgoing message form, click Delete to delete the outgoing message. To expedite text entry, use templates. For more information, see "Using Templates in Outgoing Messages".
On the outgoing message form, click Save As Draft.
To make further changes to the draft, then click Resume, enter the changes, and click Save As Draft again.
The message is saved as a draft.
Note: If you do not click Save As Draft, then the message is still saved as a draft when you navigate to another screen or view in Email Response. |
(Optional) To view the record for the draft message, select Drafts in the Saved Queries field of the toolbar.
