| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
The keyboard shortcuts in this chapter are organized in category tables according to the actions they perform. The context column indicates where in the application you perform each action because keyboard shortcuts are based on application context, or focus rules. If a command is not available in the application, then the keyboard shortcut is not active.
Some keyboard shortcuts described in the tables in this chapter do not execute the designated action in all browsers. Also, if a keyboard shortcut for an action in a table is the same keyboard shortcut for a different action in your browser, then the resulting action might be the action for your browser.
Note: The keyboard shortcuts described in this chapter are included in your Siebel application. If your Siebel administrator changes the configuration of these keyboard shortcuts, then your keyboard shortcuts might be different. Because of the browser that you use, it might be necessary to change the default keyboard shortcuts in your browser preferences or in your applications. If you encounter difficulties using your keyboard shortcuts, then contact your Siebel administrator. |
