| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
By default, notifications are enabled. As an administrator, you can enable or disable notifications. You can set notifications to operate in any of the following modes:
Always enabled
Always disabled
User enabled (default)
This task is a step in "Process of Administering Notifications".
To enable or disable notifications for an application
Navigate to the Administration - Server Configuration screen, then the Enterprises view.
From the Enterprise Servers list, select the enterprise server that runs the application with the notification settings you want to modify.
Navigate to the Component Definitions view, and select a component with a Component Type value of Application Object Manager.
In the Component Parameters list, select the Application Message Bar Flag parameter, and type the appropriate value in the Value field.
For details on how to configure the server component, Siebel Application Object Manager, or parameters, see Siebel System Administration Guide.
The parameter values are described in the following table.
| Parameter Value | Comments |
| TRUE | Specify this value if you want to always enable notifications. Note the following about a value of TRUE:
| FALSE | Specify this value if you want to always disable notifications. Note the following about a value of FALSE:
| User Enabled | Specify this value if you want users to enable or disable notifications in their user preferences. Note the following about a value of User Enabled:
