| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
As an administrator, you can customize notifications to automatically update message text that changes frequently. For example, a call center's queue statistics frequently change. Every few minutes, an administrator has to update the statistics to make sure agents have the most accurate information. This manual approach is very time consuming and inefficient when dealing with frequently changing data.
You can use Siebel EAI to automatically update notification text. Your CTI middleware or ACD switch can provide the data for the Siebel application to distribute.
The Broadcast Message business component manages the messages. Table 14-1 lists and describes the fields of this business component. These field names are necessary for developing the integration object.
This task is a step in "Process of Administering Notifications".
Table 14-1 Field Names for the Broadcast Message Business Component
| Field | Description |
Abstract |
A short summary for identifying the purpose of a message, such as Calls In Queue. |
Activation Date/Time |
The beginning of the notification. |
All |
The designation to send the message to all employees with positions defined. |
Body |
The text of the message. |
Division |
The designation to set recipients using division. |
Division Id |
The internal identification value for Division. |
Expiration Date/Time |
The end of the notification. |
Position |
The designation to set recipients using position. |
Position Id |
The internal identification value for Position. |
Recipient |
The designation to set recipients using employee. |
Recipient Id |
The internal identification value for Recipient. |
Type |
The severity of the message as defined in the type BRDCST_MSG_TYPE in the List of Values. |
Via Broadcasting |
The designation to send the message using notifications. |
Via Interactive |
The designation to send the message using Siebel eBriefings. |
The script can be created through a button, an Excel macro, or another VB application. Because it is a script and not an application, it does not need the VB Set command. All the commands are standard to VB coding.
This script is designed to update a message without an expiration date, not to create a new message every time. For more information about how to get or create a Siebel Application Object, see Configuring Siebel Business Applications.
Note: The code in this example updates single value fields. For information about how to update multi-value fields, see Configuring Siebel Business Applications. |
'Get "Broadcast Message" BusComp
Set BusObj = SiebelApplication.GetBusObject("Broadcast Message", errCode)
Set BusComp = BusObj.GetBusComp("Broadcast Message", errCode)
'Find "Calls Waiting" message
BusComp.SetSearchSpec "Abstract", "Calls In Queue", errCode
BusComp.ExecuteQuery 0, errCode
If BusComp.FirstRecord(errCode) <> True Then
'We need to create a new message
BusComp.NewRecord 0, errCode
BusComp.SetFieldValue "Abstract", "Calls In Queue", errCode
End If
’Prepare message using middleware API info.
Set Msg = "[N]Calls Waiting: [U]10"
'Update the record
BusComp.SetFieldValue "Body", Msg, errCode
BusComp.SetFieldValue "All", "Y", errCode
Write the record
BusComp.WriteRecord errCode
In addition to writing a script, you can use Siebel Business Process Designer to create or update a message. For more information, see Siebel Business Process Framework: Workflow Guide.
