| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
If a significant amount of data in a new record you want to add is similar to the data in an existing record, then you can copy the existing record, and modify the copy to create the new record.
To copy a record
Find and select the record you want to copy.
Complete either of the following steps:
Click Menu (the cogwheel icon), and then click Copy Record.
From the application-level menu, choose Edit, then Copy Record.
A new record with copied data appears.
Change the fields in the new record as needed, and step off the record to save your changes.
