| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
You might find that you want to cancel your changes to a record before you save the record. You can undo your changes to a record only if you have not yet saved the record.
Note: You cannot undo your additions in selection dialog boxes. For example, when you add employees from a selection dialog box, you cannot undo those additions. |
To cancel changes to a record
Complete either of the following steps:
Click Menu (the cogwheel icon), and then click Undo Record.
From the application-level menu, choose Edit, then Undo Record.
Note: Alternatively, press the Esc key to cancel changes to a record. The Esc key is supported only for a single undo operation. Pressing the Esc key multiple times can result in unexpected behavior, depending on the user interface element or control used. |
