| Siebel CRM Fundamentals Guide Siebel Innovation Pack 2017, Rev. A E52425-01 |
![]() Previous |
![]() Next |
View PDF |
Visualization is a type of configuration that specifies the layout to use to display the information in an applet. Card, Compact, Detail, List, and Map are all examples of an applet visualization.
To set the applet visualization
From the application-level menu, choose Tools, then User Preferences.
The User Preferences screen appears.
Navigate to the Behavior view.
The Behavior form appears.
From the drop-down list for the Visualization field, choose from the available options.
You must log out and then back in to the application for the changes to take effect.
For more information about configuring and changing the applet visualization, see Configuring Siebel Open UI.
